SOURCE: no volume
Normally when you have only one channel with audio the cause is usually SAP is turned on, either on the television or the cable or Sat elite box.
If you were pushing buttons on the remote, I would suggest that the SAP button is on the remote.
On a Samsung remote, the MTS button identifies this function. It may be labeled stereo.
Make sure the remote is in the TV mode to change or check on the TV.
It may also be a button on the remote for the Cable or Sat elite box. If not then you may have to search in the menu's of the Television or the boxes.
If the set is only two weeks old (the actual set, not how long you have owned it) then it probably has an ATSC turner labeled Air that will receive local HD by using rabbit ears. If the set is over 3 years old, it will not have this feature.
It's difficult to give a full de script explanation of a solution without knowing the model or configuration of the input signal.
If this does not help, respond to this post and I will reply.
SOURCE: Plugged Samsung TXC2516 TV directly to cable:cannot get channels
You do have to program the tv in a different search mode, I just checked online and if you go to google and put in manual for and then your tv model it will give you various options so you can download the manual for your tv, or if you want more specific the link that I found was http://www.servicemanuals.net/ServiceManual/SAMSUNG/TXC2516+CX/pos1/results.aspx
SOURCE: SNOW AND DON'T KNOW IF ITS ON RIGHT CHANNEL FOR DIRECT TV
If possible connect via one of the rear sets of audio and video inputs from the direct box--this is more common than using tuner in set.
