Question about Jensen Televison & Video
Does Jensen TV model JE1913AC2 have a builtin QAM runes.
2 Suggested Answers
SOURCE:
paul4265
  • 592 Answers
SOURCE: I have a Jensen TV, Model Number TS2050J. I need
Hi.
No, your tv is an older model sdtv with an analog only NTSC tuner.
Newer model have an ATSC/Qam digital tuner, but not your model.
This means that if you want to watch tv, you'll have to get a converter box. It will have the ATSC/QAM tuner i it, and it converts the signal into lower definition NTSC, and then sends it to the tv through either coax cable, or rca cables.
Once in a great while you might even find one that has s-video output, but those usually are expensive.
I hope this helps you out.
Posted on Feb 08, 2011
How can i get a QAM code?
QAM codes are to do with the way digital TV is encoded. There's nothing practical you can do with a QAM code. It's like understanding how to calculate the mass of Jupiter. Great that you can do it. But it's of no practical day-to-day benefit.
Here's some reading on Quadratic Amplitude Modulation, for what it's worth.
Comparison of 8 QAM 16 QAM 32 QAM 64 QAM 128 QAM 256 QAM Types
Sep 08, 2014 | Seiki Televison & Video
What is the QAM code for a flat screen tv? model #se22hs01
You don't need the QAM code. QAMs are to do with how digital TV is encoded. There's no information in a QAM that you can use as a consumer.
I have a Jensen TV, Model Number TS2050J. I need to know if it has a QAM tuner built in.
Hi.
Feb 08, 2011 | Jensen TS2050J 20" TV
My Brand New 40" westing
To get HD channel form your cable TV without using the cable provider HD tuner box but using your TV Clear QAM tuner (your TV has Clear QAM tuner, my TV also has QAM tuner so I do not have to use the cabel box, but my COMCAST does not provide may Clear QAM signals like they use to) to get the unscrambled HD, the cable provider must provide those unscrambled Clear QAMsignals for your TV to pick up the signalS.
Learn more about Clear QAM cable signals:
http://en.wikipedia.org/wiki/QAM_(television)
Did you use the correct setup during the tuner setup to scan the availabel cable channel per user manual?
Dec 30, 2010 | Westinghouse SK-40H520S 40 in. LCD TV
Does this model have a built-in QAM tuner?
Yes it does.
  • Includes built-in ATSC/QAM/NTSC tuner for off-air HDTV and SD (standard-definition) reception
  • Accepts high-definition 1080i, 720p, and 480p signals from DTV set-top receivers and progressive-scan DVD players
  • Side-panel A/V hookups and controls allow easy connection with a camcorder, gaming console, or other device
  • Aug 15, 2009 | Samsung DynaFlat TX-P2775H 27" TV
    How do i know if my tv has a quam tuner im not
    First it is QAM (quadrature amplitude modulation) and is used only on cable systems. Know that you will only get clear-QAM, this is, those not encrypted. This means only the local channels, which they are not allowed to encrypt. It will switch automatically, so if you get any HD it will be QAM. They will have names like 85-1 for digital source, not necessarily HD. Not all set-top boxes can tune digital channels--check with your cable system. You have called them? Be sure to remind them on your STB make and model, they may need to replace it. -Ken
    Jul 16, 2009 | Samsung Televison & Video
    Ready for nat'l digital transition?
    If it is an older model (i couldn't find anything on it either), it most likely does NOT have a QAM tuner. Be aware that only the "un-encrypted" cable channels will be free otherwise you will have to buy or rent the digital box from the company to get the rest of the regular digital channels. The un-encrypted channels are like 71.2, 83.7 so you should know if you are getting those or not.
    May 23, 2008 | Recoton Advent Advent HT3251A TV
    Televison & Video Logo
    Top Jensen Televison & Video Experts
    Jaime Hernandez
    Are you a Jensen Televison and Video Expert? Answer questions, earn points and help others
