Televison & Video Logo
Richelle Ostonal Posted on Jun 20, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to connect my cable box to old Sylvania tv
john h
Level 3:
Top Expert:
  • Sylvania Master 29,494 Answers
  • Posted on Jun 20, 2018
john h
Sylvania Master
Level 3:
Top Expert:
Answers
29494
Questions
0
Helped
7560143
Points
193449
Go to store[s] that sell electronics and look for an adapter --or online search for an adapter
Testimonial: "I've got an adapter already but I bought it used"
5 Related Answers
Anonymous
  • 2071 Answers
  • Posted on Jul 16, 2008
SOURCE: Hook-up
first you do connect cable to your > combo VCR / DVD player & recorder then connect to > to your TV:
cable coax output or if that cable have video/audio ouput is going to INPUT >to combo VCR / DVD player video / audio output is going to INPUT > to TV,.that's the time you can record and playback;
click below for more information in hooking up:
DVD Players/Recorders: Home Theater Setup, Installation & Hook Up ...If i have helped,please click fixya,it is the only way i get paid for my work ,also please consider leaving feedback...
Good luck ,and Thank you in advance:
Anonymous
  • 196 Answers
  • Posted on Nov 29, 2008
SOURCE: Sylvania DVC850C after the February conversion
Simple answer is no.. not if it does not have a freeview tuner that goes for all those recorders out there that are not digital you could of course attach a freeview set top box to it but in my opinion with recorders being literally dirt cheap these days it's not worth the bother
Anonymous
  • 448 Answers
  • Posted on Dec 31, 2008
SOURCE: how do i connect a panasonic theater system to asylvania tv
For best results either use an s-video connector and RCA Red/White for the audio. If no s-video available, use comp which means composite (Red,Blue, Green) so the truest color can go from one unit to the other. On the back of the theatre system, plug everything into "output", on the panasonic, input.
Anonymous
  • 52 Answers
  • Posted on Jun 18, 2009
SOURCE: Cox Cable Remote wont program to my Sylvania LC320ss8 tv.
there are different codes for the devices that you are using. When you want to insert the code for the tv. > Switch tv on and then switch all the other devices off. Insert code. For digi box > switch on and all other devices off. Insert code for digibox. You must then switch between tv and digi box using the buttons on the top of the remote. Toggle between tv/ digi box.
Have a go with the codes below with the tv and the digibox both on, you never know you might get lucky as these are new codes, if not revert back to 1st solution.
Universal Codes (both should work using these, i think!!!!! try 'em)
002,
008,
155,
198,
227,
231
Here are the codes for the 1st solution.
Good Luck,
Hughie.
Tv
0062
0004
0009
0135
0189
0183
1141
0227
0456
0008
0068
0075
0141
0161
Digi Box.
0899
0227
0287
0290
0225
0456
0251
0292
0236
0458
1106
timtation123
  • 56 Answers
  • Posted on Jun 26, 2010
SOURCE: Sylvania 15 inch digital/analog LCD TV HDTV. Once
try doing the auto search method on the cable remote. sometimes this works when the codes do not. if it doesn't then it is what it is.
Why no tv picture on my Sylvania #ssc092 ac/dc tv/vcr combo?
it is a very simple TV, is TV connected to cable? Here is link to manual copy and past download and save for future reference. It is very old and has CRT not LCD.
https://www.manualslib.com/manual/776815/Sylvania-Sylvania-Ssc092.html#manual
How do I connect a Sony DVD DVP-SR210P to a Scientific Atlanta Explorer 4240 HDC and a Sylvania TV C320SLX?
I am not sure you can connect your DVD player to your cable box. You should be able to connect both your cable box and DVD player to your TV set with two HDMI cables. This link is a pdf_usecares file of the TV manual that shows how to hook up your dad and cable box.
http://www.managemylife.com/mmh/pd_download/lis_pdf/OWNM/L0902617.pdf
Hope this helps.
Bob
1helpful
I have connected the cable line to the vcr/dvd player and the player to the sylvania TV, but I cannot get the picture to come on. The television function works fine. Are there some other cables or another...
Is there a box from the cable company? If so, you will need to tune the TV to the channel that the box outputs it's signal on. Usually it's either channel 3 or 4. Whether you have a cable box or not, make sure in the set-up menu for the TV, that you have selected "cable" not "air" as your signal source. Write if you need anymore assistance.
I can only get a few channels on sylvania tv
If you have a cable box connected, you have to set your tv in the menu for cable/satellite and not antenna.
Sylvania television - no sound / lost digital signal
change antenna input to on air or antenna
1helpful
Sylvania 6842 PE 42 in...
You need an HDMI cable that runs from the cable box to your tv.
1helpful
HELP! I can't figure out how to Connect my Sylvania DVD/VCR Combo to my older TV
Even if you do get it connected you cannot copy from vhs to dvd as you have bought a vcr recorder with dvd player, not a dvd recorder. You can only record to the vcr tape from a dvd, in the players controls.
Top Sylvania Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
