Grinders Logo
Fred Fenton Posted on Jun 19, 2018
Does a Craftsman 6 Inch bench grinder model no. 319.190620 require lubrication?
I have to manually start wheel turning.
Ralph Andersen
Level 1:
New Friend:
  • Contributor 12 Answers
  • Posted on Jun 19, 2018
Ralph Andersen
Contributor
Level 1:
New Friend:
Answers
12
Questions
0
Helped
4756
Points
37
Closed bearings --no problem
4 Related Answers
Anonymous
  • 2176 Answers
  • Posted on Dec 28, 2009
SOURCE: I need a replacement switch for a craftsman 1/2 HP bench grinder
this switch is no longer available from Sears, so I suggest making a wiring drawing and taking the switch to a local electrical supply house and try matching it up with a replacement. It seems to be a simple on/off type switch and I would think that you should have no problem. Let me know if you do and give me the information on the switch and I will try some other sites I know.
Testimonial: "Great solution. Yhank you. - b"
eugbug
EugenesDIYDen
  • 479 Answers
  • Posted on Apr 25, 2011
SOURCE: HOw do I change grinding
There should be a guard over the wheel, held by several screws. Remove this. The nut holding the wheels loosen in the same direction the wheels turn so this would be anti-clockwise for the right hand wheel and clockwise for the left wheel. When replacing the wheel, ensure you replace the cardboard or rubber washers on the wheel. These spread the pressure evenly when the nut is tightened.
Oliver Street
  • 73 Answers
  • Posted on Jul 26, 2012
SOURCE: need manual for craftsman bench grinder model #
Mike
Not sure what was happening when the previous reply was created, but the owners manual is part number 211260001 $7.99 at SearsPartsDirect.com
That said, I'm staring at my own copy of the the owners manual and I can't really see why you would want to pay for one. The only really useful information is the parts diagram which is online at SearsPartsDirect.com. The rest is generic grinder information (support workpiece, select proper wheel, etc.) and CYA (always wear gloves and eye protection, don't remopve safety guards, don't use damaged wheels, don't stick your finger in the light socket, don't cross the steet in the middle of the block, etc.)
torqueman200
W Michael S
  • 12 Answers
  • Posted on Feb 25, 2016
SOURCE: How do you tighten the nuts when changing the
There is a left handed thread and a right handed thread on the arbors.
The double-nut method is preferred.
OR
Removal
Right Hand Side (RH)
Wrap a piece of rubber or leather around the threads on the LH side of the arbor & hold with pliers, while turning the RH nut CCW.
Left Hand Side (LH)
Wrap a piece of rubber or leather around the threads on the RH side of the arbor & hold with pliers, while turning the LH nut CW.
Installation
Note: Hand tighten the nut, then 1/4 turn.
Wrap a piece of rubber or leather around the threads on the LH side of the arbor & hold with pliers, while turning the RH nut CW.
Left Hand Side (LH)
Wrap a piece of rubber or leather around the threads on the RH side of the arbor & hold with pliers, while turning the LH nut CWW.
For grinding stones:
ring test the stone discard the stone if it has been dropped be sure the paper washers are installed on the wheelGRINDER SAFETY 101 (graphic injury video so be warned)
http://www.garagejournal.com/forum/showthread.php?t=263083
HOw do I change grinding wheels on a 6 inch Craftsman bench grinder? Thanks.
How do I remove the wire brush form a model 9410 grinder?
An ajustable wrench for the 'wire brush end' nut,and a visegrip type plier for the opposing wheel end. Wrap the jaws of the visegrip pliers with tape to protect the spindle opposite the wir wheel. Loosen the nut on the wire wheel end,counterclockwise.REMEMBER: lefty loosey-righty tighty.
2answers
Model 397.19471 need switch but can not find. please help? 8 inch bench grinder
Call the Sears Craftsman help line they will have the parts you need
Grinder starts and runs then peters out and gets pretty warm. Is capaciter bad?
Most probably. the motor will overamp, get hot and go out on internal overload.
Craftsman manual for Model 21126 6" grinder
What do you need a manual for? It's a grinder, grind something!!
3helpful
2answers
Need manual for craftsman bench grinder model # 257.191300. misplaced other one. hope you can help. mike
Mike
Bench Grinders Featues
A bench grinder is a very simple tool. The units are usually listed as 6-inch or 8-inch wheel models, and the 8-inch units are typically a bit more powerful, and subsequently more expensive. A 6-inch model will usually be powered by a 1/2 HP motor, where the 8-inch will be larger, likely 3/4 HP. Two very useful features to look for are a mounted work light, which will directly illuminate your work, and an adjustable rest, which functions much like the tool rest on a lathe. Strongly consider models which have both features. Many also include a clear, see-through spark guard, which will help keep any sparks from flying toward your face. A word of caution, though: such a guard does not replace safety goggles.
Top Craftsman Grinders Experts
Oliver Street
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Craftsman Grinder Expert? Answer questions, earn points and help others
