Garden Logo
D
Don Atkinson Posted on Jun 19, 2018
Rubber plug petrol tank for atom edger mod.101. 102 thanks
Steve
Level 1:
New Friend:
  • Contributor 30 Answers
  • Posted on Jun 21, 2018
Steve
Contributor
Level 1:
New Friend:
Answers
30
Questions
0
Helped
17587
Points
85
If you're referring to the grommet where the fuel lines enter the fuel tank, just go into any mower shop and ask for a Ryobi tank grommet. It is effectively a generic item and is interchangeable with almost all 2 line grommets.
Alternatively, as an Atom dealer, I could order the genuine part in for you.
1 Related Answer
mickey813
mickey813
  • 472 Answers
  • Posted on Dec 08, 2009
SOURCE: ryobi petrol weed eater
SOUNDS LIKE YOU MAY NEED TO REPLACE THE FULE LINES THAY DO GET BAD OVER TIME
Engine willnot start
Try taking out the spark plug,see if its wet,is the primer bulb ok?does the bulb fill with petrol when you press it,if this is ok,check the carb for dirt,and or the tank,is your petrol mix correct,as this makes a big difference to the run ning of the machine,rgds
1helpful
I just bought a used Craftsman 3.8 Briggs and Stratton Edger. It works great but leaks gas after I quit using it. It seems to come from underneath a round aluminum bowl. How would I look to fix this?
probably missing seal to the carby bowl, undo the round bowl (watch out for petrol/drain tank first ) then check to make sure the bowel has a rubber seal . if not auto shop should be able tio locate one if you take the bowl in tp size it . or you can use a gasket sealer thats petrol proof
Ryobi petrol weed eater
3helpful
Petrol strimmer good spark but wont start
if it ran fine then it quit it is more likely the pick up tube in the fuel tank
Sep 14, 2009 • Garden
Engine cut out!
could have water in fuel bowl or tank,coil could be heating up and stop firing or the plug
Sep 09, 2009 • Garden
Petrol In Spark Plug Area
buy a junk vacume that runs an **** out the petrol with it and replase the spark plug
Jul 28, 2009 • Garden
1helpful
Gas tube came out of gas tank
If the rubber stopper is still plugged into the tank pry it out go to a small engine shop and buy new gas line.Thread the new line into rubber stopper to poper length,plug filter (new)on end that is going in tank then pop he rubber stopper back into the tank body.Have done hundreds and it isn't hard,you may need sone WD 40 on stopper to thread line and popping stopper back in .Good Luck
The guy i bought this bike from was an idiot the hoses and vacume lines are messed up i need help with any diagrams help the lost.THANKS
Small bore pipe from inlet side of no 2 carb goes to the small bore pipe on the petrol tap (this is the vacume swich pipe)
Large bore reinforced pipe goes from the large pipe on the petrol tap to the (hidden and bugger to get at) connector that points up (on the airbox side) between no's 2 & 3 carbs on the airbox
A large bore pipe goes from the rear facing connector on top of the centre cover on top of the cam cover (located under the frame beneath the petrol tank) to the connectot on the air box (this is the breather pipe)
Ensure that all pipes are hole/split free, secured with clips and that each inlet mainfold rubber (between the carb and cylinder block) has it's vacume plug fitted (located at the bottom of each rubber)
Ryobi line cutter - petrol lines all broken
Petrol lines disintegrate when fuel is stored in the trimmer for long periods of time. These can be obtained from any small tool repair store. Just remove them and install new ones. They just slip through the holes in the tank, re-attach the fuel filter on the supply line. Make sure that the line is long enough so that the filter rests on the back/bottom corner of the tank. Be sure that the lines are attached to the proper ports on the carb>
Top Garden Experts
Jay Finke
Jay Finke
john h
