Computers & Internet Logo
M
Maurizio Badami Posted on Jun 19, 2018
Polycom KIRK 4020 " reset impostazioni di fabbrica?
1 Related Answer
Muzahura Frank
  • 2071 Answers
  • Posted on Jan 24, 2011
SOURCE: HO UN TELEFONO CELLULARE W008E
ok in english,
I HAVE A MOBILE PHONE WI FI W008E DVB-T, I DID THE RESET CONDITIONS FOR RETURN TO FACTORY BY THAT TIME THE TOUCHSCREEN has stopped working, THEN I CAN NOT USE ANY FUNCTION WITH TOUCHSCREEN, the keys manually works fine. IS THERE A RESET BUTTON OR ANOTHER WAY TO DO IT WORK? Thank you and greetings
solution:
you have to reflash the phone. that is load the firmware again. this is a common problem with those chinese phones and the reset causes data corruption in its firmware. for this, you require special tools and software and purchasing them may also not be cost effective. if you can take to a service shop do that but if you wanna try it your self, please click here for further guide on requirements.
regards
2answers
I HAVE AN KORG i3 AND NEED REPLACE THE INTERNAL BATTERY BUT I DONT WHERE IS
You will need to open up the keyboard. Make sure it is unplugged. Once you take out all the screws that hold the top half with the bottom, separate the two carefully. You will have some wires and ribbons attached to both sides. The battery is on the circuit board, it looks like a quarter. Make sure you replace the same size battery.
Dec 06, 2016 • Korg Music
La lettura del CD si interrompe con qualsiasi tipo di cd, originale o masterizzato
Avrete bisogno di raplce l'unita CD, si e rotto. E possibile contattare la fabbrica per servizi o potete trovare un riparatore locale.
AIUTATEMI!!!! NON RIESCO A COLLEGARE INTERNET
Nintendo DSi / DS / Ds XL si connette a Internet tramite connessione wireless. ? necessario conoscere le impostazioni del router. Sono elencati di seguito i passi su come si intende accedere al router e ottenere le informazioni necessarie per voi da collegare.
Come accedere al router:
1. ? necessario conoscere il ipaddress del router. ? possibile fare riferimento al manuale o controllare il gateway predefinito del computer (Assicurarsi di collegare il computer al router tramite un cavo Ethernet per voi per ottenere il gateway predefinito). Fare clic su Start poi Esegui. CMD tipo sul piccolo riquadro in basso a sinistra dello schermo. Tipo IPCONFIG nella finestra nera e ottenere il valore della vostra gateway predefinito (che inizia con 192.168.xx)
2. Aprire un browser, digitare il gateway predefinito sulla barra degli indirizzi del vostro browser. Vi chieder? un nome utente e password. (Consultare il manuale del vostro router o inserire un messaggio in modo che io in grado di fornire il nome utente e la password del router)
3. Vai alla pagina delle impostazioni wireless del router. Cercare il SSID o il nome di rete e theNetwork chiave o passphrase. Si pu? personalizzare in modo che si pu? facilmente ricordare i dettagli.
4. Assicurati di collegare al proprio SSID e inserire la chiave di rete per renderlo sicuro.
Ora che sappiamo gi? le impostazioni del router poi il suo momento di collegare il Dsi alla rete.
1. Vai alla Nintendo Wi-Fi Impostazioni di connessione del Gioco
2. Ricerca di un Access Point (SSID)
3. Seleziona la tua rete (SSID), Se si dispone di una rete aperta, basta cliccare su "OK" e dovrebbe funzionare bene! Se si tratta di un lucchetto rosso, sar? chiesto di specificare una chiave di password o di rete. Questo ? il motivo per cui reson accedere al router.
4. Verificare la connessione.
Voglio inserire la password
Eseguire un ripristino di fabbrica (il bottone di ripristino di presa nel retro del canale per 30 secondi o più) IP 192.168.0.1
l'ammin. = la parola d'ordine di ammin. = la parola d'ordine
Perform a factory reset ( hold reset button in the rear of the router for 30 seconds or more )
IP 192.168.0.1
admin = admin
password = password
Se potrei essere di assistenza ulteriore, fatemi sapere. Se questo aiuta o risolve la questione, lo valuta per favore e dà un benservito per i miei Ringraziamenti di risposta, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Quando finisci di scrivere una lettera yaoo messenger finisci di scrivere una lettera come si fa ha mandarlo
infezione da nuovo virus: pu? essere fissato attraverso l'eliminazione chiave extra nelle impostazioni del Registro di sistema. vai a HKEY_CURRENT_USER \ Software \ Microsoft \ Windows \ CurrentVersion \ Internet Settings \ quindi eliminare le chiavi diverse 0,1,2,3,4 avere qualcuno che sa intorno registro di Windows per impostare nel modo giusto .. buona fortuna
Io non parlo italiano, io uso google translate
2answers
SAMSUNG S8300 QUANDO MI CHIAMANO I CELLULARI , IL TELEFONO RIMANE IN MODAITA' VIBRAZIONE, SENZA EMETTERE NESSUN SUONO. GRAZIE, DESY
Spero che non sembra troppo ovvio, ma hai provato di cambiare il profilo? Menu --> Impostazioni --> Profili
Mi scusa se sia qualche errore - l'italiano non e` la mia madrelingua.
Nu pot sa instalez yahoo mesenger
impossble scaricate i file necessari per linstallazione di yahoo! messenger. verifica le impostazioni del firewall e prova a riprendere linstallazione
Chiedo rimborso.
Ciao Carmelo.
Dovresti dirci a proposito di cosa stai chiedendo il rimborso.
Se il rimborso di cui stai parlando e' la quota di iscrizione a Fixya, per favore chiedi il rimborso scrivendo a [email protected].
Se invece hai comprato il computer con una sovvenzione, ed il computer non funziona, il rimborso puo solo essere concesso dal commerciante, immediatamente dopo l'acquisto, e solo in accordo con i termini e le condizioni di vendita.
Spesso non e' possibile ottenere nessun rimborso, particolarmente in Italia (in Inghilterra hai 15 giorni).
Se il computer e' diffettoso, quello che puoi fare e' ripararlo sotto garanzia. Per questo devi chiamare il numero scritto nel libretto di istruzioni.
La fabbrica coprira' le spese di riparazione entro un anno dall'acquisto.
Saluti.
Hp dv 6373
CIAO, or you have a bad motherboard or bad the battery connector on the motherboard.
Arriverderci!
Top Polycom Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Polycom Computer and Internet Expert? Answer questions, earn points and help others
