Question about Samsung Televison & Video
Samsung UN60JS7000FXZA TV. The standby light is on but the TV will not come on.
I opened up the back and didn't see anything obvious like bulging capacitors. There is a clicking sound on the power board and an intermittent humming noise from what appears to be the t-com board.
    Top Expert:
  • Samsung Master
  • 51,832 Answers
Open internal fuse or power supply failure
Posted on Jun 18, 2018
Start by trying to reset your TV. Disconnect the power cord from the outlet, then press and hold the power button on the TV (not the remote), for at least 10 seconds. Then wait a few minutes and plug the TV back in and press power once. 2 blinks on Samsung TV's usually indicates a bad power supply.
https://www.besanttechnologies.com/training-courses/cloud-computing-training/amazon-web-services-training-institute-in-chennai?utm_source=backlinks&utm_medium=qa&utm_campaign=coursepage&utm_term=aws&utm_content=gowsi
Posted on Apr 20, 2019
Start by trying to reset your TV. Disconnect the power cord from the outlet, then press and hold the power button on the TV (not the remote), for at least 10 seconds. Then wait a few minutes and plug the TV back in and press power once. 2 blinks on Samsung TV's usually indicates a bad power supply. https://www.besanttechnologies.com/training-courses/software-testing-training/selenium-training-institute-in-bangalore?utm_source=backlinks&utm_medium=forum&utm_campaign=coursepage&utm_term=selenium&utm_content=Mounika
    Problem Solver:
  • 6 Answers
Hi sounds like 1 off the capacitors have blown or failed if you got a bit of electrical knowledge u can locate and change it urself or buy a working pcb and swap it ok
Posted on Apr 19, 2019
    Problem Solver:
  • 5 Answers
Start by trying to reset your TV. Disconnect the power cord from the outlet, then press and hold the power button on the TV (not the remote), for at least 10 seconds. Then wait a few minutes and plug the TV back in and press power once. 2 blinks onSamsung TV's usually indicates a bad power supply.
Posted on Apr 12, 2019
SOURCE:
  • 927 Answers
SOURCE: Which Replacement Power Board for LNT4665F Samsung LCD TV?
Howdy,
It would be a lot cheaper if you just replace the two caps that have gone bad. Just get a cheap solder pencil from the store and about an inch of solder and you are in business.
The Power Supply Board is the center Board (towards left) after you remove the back off the TV. Remove Board from TV with the 6-7 screws. Replace capacitors CM852 & CM853; 2200ufd 25volts.
Thaks for using FIXYA, BIG IRISH.
Posted on Jan 02, 2010
SOURCE: Samsung TV clicking and won't come on
Did you find out if that would solve the problem? I was really excited to learn that all I needed to do was change out the capacitors but after installing 4 it continued to click. I to removed the cover to the and found the relay where the noise is coming from
Posted on Jan 29, 2010
  • 304 Answers
SOURCE: I have a Samsung LNS3251D 32-Inch LCD HDTV , that
In almost all cases where the set is taking a long time to turn on and then turning off it will be the Power Supply board that will have bulging capacitors, usually three to five. Look on the upper right side of the Power Supply and look for any blown caps. You can replace these caps and you will be fine. Now the other cause can be the Power Switch is shorting out. You can disconnect the the Power Switch but not the IR sensor and then turn ON the set with your TV remote and see if this stops the problem. If you are not skilled in component level repair on the Power Supply board then buy a new Power Supply board and install it.
Posted on Apr 16, 2010
  • 1273 Answers
SOURCE: Samsung LN46A550 LCD power on/off
Apparently this is a known problem with flat panel TVs made a few years ago due to bad capacitors in the power supply. This same problem appeared in computer mother boards at about the same time so that the capacitors went open or shorted causing problems.There is videos on You Tube that addresses this problem see: http://www.youtube.com/watch?v=ZccykxrtX9g as a starting point and look around for other repairs
Posted on Jan 25, 2011
budmrtn
  • 11361 Answers
SOURCE: TV WONT SWITCH ON LE26A456C2D standby light blinks
Please read my giude then you may understand more as to what it takes to make the TV functions.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Please leave rating if it helps.
Posted on Mar 06, 2011
I need help with a Samsung LCD TV.
Is the TV totally dead now, no standby light?
Sep 10, 2018 | Samsung Televison & Video
Samsung TV will not power on
The tv have problem with its mother bord. As it have Smd components it's not possible to repair it. You have to replace the Board. If you wish to get some details about television repair then check the following link
http://electro-medical.blogspot.com/
Aug 19, 2016 | Samsung Televison & Video
My samsung plasma tv powers on has sound and a picture, but is snowy, and coloring is slightly off. I have opened the tv to check for bulging caps and have found no obvious culprits. what next?
Snowy pics are not the symptom of bulging caps.
you must mention what type of source produces 'snowy' pics.
have you tried with other sources and ports ?
I recommend, you test out the following.
- DVD with Component connection
- HDR or STB with HDMI
- TV/Antenna
Aug 15, 2016 | Samsung Televison & Video
Samsung plasma TV wont turn on.
A capacitor can be bad without bulging. Is it a constant clicking or just one?
Apr 19, 2013 | Samsung 51"" Class 51.0"" Diag. Plasma 530...
My tv showing an amber light instead of red standby light and now it won't switch on
Good day!!!
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
Jun 20, 2012 | Televison & Video
Optima ep716 power light flashes green but cannot turn on projector?
The green flashing light is jsut indicating it is in standby mode.
Just double check the connectors are in place and do not have any damaged pins. If the input is active from a laptop- make sure you have the external monitor enabled- some you have to manually enable, some you merely need to have the monitor plugged into it.
If all of that is okay and functioning, and it still will not get out of standby, open the unit and check the wiring to the DB15 connector for a broken wire, If those check out, visually inspect the power supply for any bulging electrolytic capacitors- if any are found, replace them with high ripple current types.
Feb 07, 2012 | Optoma EP716 Multimedia Projector
Orange Standby Light.
Your power supply board may be damage. It cost about $100. Labor cost I do not know at your residency. You can search TV repair shop by www.tvrepair/man.com
Aug 13, 2009 | Samsung LTN1535 15 in. HD-Ready LCD...
Televison & Video Logo
1,100 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
