Question about Stanley Garden
Looking for replacement Stanley 61814 backpack sprayer parts. Replacement spray nozzle. Know where I can get them?
    Top Expert:
  • Stanley Master
  • 29,172 Answers
5 Suggested Answers
SOURCE:
scrodamoon
  • 659 Answers
SOURCE: Stanley 4 gallon backpack professional sprayer.
well thats metal and where there is metal find someone to tack it back together and brace it on better so it dosent happen again. other then that you would be purchasing a new unit I have found replacement pumps for this unit but not the pump handles so unless there is one out there that is used and needing a home I would proably try to contact the manufactuer themselfs or where you bought the unit ask them if they can order in replacement parts for the unit.
Posted on Aug 03, 2008
  • 438 Answers
SOURCE: Stanley 61804N Professional Backpack Poly
Doc,
Yes, please replace the seal.
Posted on Mar 05, 2011
mark24354
  • 776 Answers
SOURCE: I need a new rubber
Drive out to the country side and look for a ACE or TrueValue hardware store. Bring your sprayer with you. They will likely have the right part for you in stock.
Posted on Sep 09, 2011
H2_Brad
  • 425 Answers
SOURCE: Where to buy replacement nozzle spray piece
It looks like Sears has parts available.
HOOVER Upright Extractor Parts Model F5858 920
Posted on Jul 06, 2014
Spray not working, doesn't stop water from faucet.
It sounds like a kinked hose under the sink or a clogged nozzle. Unscrew the nozzle from the sprayer and check for calcium buildup. New parts can be purchased cheaply from the local hardware store, take the old parts in and a sales rep can help you with the correct parts. Some sprayers have replacement nozzles...unscrew the old and screw in the new.
Sep 20, 2015 | Plumbing
4-gallon backpack sprayer sprayer needs a new spraye part
go to the hardware and buy a spare part to replace broken bit
Jul 15, 2014 | Garden
Parts sprayer stanley
I would like the answer yo that question
May 10, 2013 | Stanley Professional Backpack Poly...
I need a new rubber seal for the plunger piston on my stanley backpack sprayer. Where can I get one of these? Is there a web site for ordering these parts?
Sep 09, 2011 | Stanley Professional Backpack Poly...
Best spray tip nozzle for herbicide application, SOLO 425
tee jet yellow nozzle with metal inserts john deere/lesco sells them in packs of four these are best for 1 gal per k spot treating selective herbicide ......round up just use the adjustable cone
Jan 14, 2011 | Solo Backpack Sprayer
I have a Stanly backpack sprayer pro 61804n and need a repair manual. Were could I find one. Thank You, Chuck
The picture looks a lot like a Solo sprayer I have. I wouldn't be surprised if Solo made them for Stanley. Do a search for Solo sprayers. They have a site. My sprayer is a Solo 425
Jun 21, 2010 | Stanley Professional Backpack Poly...
The spray unit bent and broke...
Lowes or Home depot sells replacement sprayers. Hose to tip all included.
Aug 18, 2009 | Stanley Professional Backpack Poly...
Sprayer Question
Hose end sprayers are the simplest and least expensive of the category. A sprayer jar is attached to a regular garden sprayer. Concentrated material is added to the sprayer jar. An adjustment on the jar determines the amount delivered. The force of the water through the hose pulls the material up from the jar and mixes and dilutes it with the water. A built-in anti-siphon device prevents unused material from being pulled back into your water supply. Compression or tank sprayers are the most common type of spray equipment. Concentrated material is added to the tank. Water is then added to a marked fill line. The remaining air is pressurized by pumping the handle a designated number of times. A control lever on the wand controls the spray pattern and amount. Compression sprayers provide a precise, on target, non-drift spray good for soil and lawn pests. Adjust the sprayer for a coarse, drenching spray, a concentrated stream or a fine mist. Tank capacities range from 1 quart to over 3 gallon for handheld models. Homeowner type backpack sprayers hold up 4 gallons. The tanks may be made from polyethylene plastic, galvanized steel or stainless steel. In addition to treatments for pests and diseases, compression sprayers are designed for applying cleaning solutions for decks and siding. Backpack sprayers are operated in the same manner as the handheld compression sprayer. The over-the-shoulder configuration makes it easier to carry the heavier load of material. Some backpack models also use a lever-style pump to maintain pressure without removing the unit form your back. Powered sprayers rely on a gasoline engine for spray power. Great for larger yards or gardens due to portability and capacity (12 gallons). Dusters are a slightly different breed. Dry powders (mostly for blooming plants such as roses) are added to a canister and applied by manually pumping. NOTE: Compression sprayers deliver liquid under pressure. Compression sprayers are powerful and efficient tools. This fact also makes them potentially dangerous. Always read the manufacturer's instructions and safety precautions carefully.
Aug 27, 2008 | Sp Systems 02sv320065 Farm & Home 2 -...
Garden Logo
242 people viewed this question
Top Stanley Garden Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
mpservices
Andrew Taylor
Andrew Taylor
Are you a Stanley Garden Expert? Answer questions, earn points and help others
