Refrigerators Logo
C
Callum Duncan Posted on Jun 18, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi I am looking for a user manual for Samsung SRS580DHLS side by side fridge/freezer. can anyone help or tell me how to reset the water filter warning light. Thanks Gallum.
Terry
Level 3:
  • Samsung Master 11,377 Answers
  • Posted on Jun 18, 2018
Terry
Samsung Master
Level 3:
Answers
11377
Questions
Helped
4626107
Points
152765
Https://www.samsung.com/au/support/model/RS21HPUSL1/XSA
http://downloadcenter2.samsung.com/content/UM/201407/20140723172217328/DA99-02318A-12.pdf
See manual:
FILTER
CHANGE
BUTTON
When you change the filter,
press this button for 3
seconds to reset the fi lter
schedule.
5 Related Answers
Anonymous
  • Posted on Sep 21, 2007
SOURCE: Samsung RCS21DCNS Side by Side
probly the evaporator coil in fridge all frozen up you need to pull all the back out inside the fridge section and defrost with air drier
shaggyrat
Christophe Thompson
  • 1224 Answers
  • Posted on May 13, 2008
SOURCE: filter indicator on samsung side by side fridge freezer is on
2 places filter can be top left upper corner of fridge or behind the fridge with a little longer filter type
the smell could be the filter but i would pull all drawers and shelves and i would check for mold also the possibility of water leak behind panel of water spout that has molded over this smell you could never forget cause smells like old gym socks
Anonymous
  • Posted on Oct 12, 2008
SOURCE: samsung water filter rs21 dcns
Hold down the "ice type" and "child lock" buttons (bottom button on the left and the right) together for about three seconds. The light will change back to green.
chapichapo
  • Posted on Feb 13, 2009
SOURCE: Water Filter Not working
Hi Nicky,
We just had the same problem; and we've solved it.
Press the MENU button (4 times) until the Pure Water LED is flashing; then press and hold the SET button down until the screen goes back to the main menu.
SORTED!
Catherine & Matthew
Anonymous
  • Posted on May 04, 2009
SOURCE: Samsung RS20CCMS side by side fridge/freezer
Just to expand on the excellent advice from woodchuckie - I had the same problem and these are the steps I took to resolve.
1) Remove the back panel. There are about 7 screws to undo.
2) The drain tube is towards the middle about 3/4 inch in diameter.
3) Remove the tube. I found a little black rubber 'flute' which I have now removed as I think this was causing some back pressure. Make sure the tube is clean and free from dusty gunk. Mine was anyway hence the removal of the flute.
4) Remove everything from the lower 2/3s of the freezer compartment. Remove the screws (some are covered by white caps) there are about six. You must remove all the screws up to the place where the top panel starts.
5) The back panel may be frozen in place. From a standing position reach down and grab the protruding plastic - pull up and out. The panel should loosen. Turn it sideways to remove it.
6) You should now see the freezer matrix and the frost free heater pipes at the bottom. If your like me you will see a block of ice at the bottom!!
7) I took a hair dryer (carfull of the water/electricity hazzard) and melted the ice (also be careful about melting the plastic of the freezer!! doh).
8) With a sponge remove the loose water.
9) The drain is in the middle and is difficult to get to.
10) I took a screw driver to the hole and jabbed at it.
11) Boil a kettle and fill the shallow tray around the drain. If your lucky the water will work through quickly and you'll hear it falling into the evaporation tray. If not then keep sponging the water out and replacing with boiling water (and have a few more jabs with a screwdriver!). Keep working it untill you have success.
12) Ensure that the interior of the freezer is dry ( I blew some air from the hair dryer through the drain and got someone on the drain at the back to confirm they could feel it coming through.
13) Replace all the plastics, back panel and screws. Put everything back in the freezer, plug it back in and set it to power freeze.
The whole thing took about 45mins - 1 hour.
Hope this helps.
I have a 6 month old Samsung French style refrigerator with water/ice in the door. After changning the filter, sounds like water dripping.
Hi Tammy,
Please check there https://manualsbrain.com/en/brands/samsung/fridge-freezers/ for a manual to your fridge (or a fridge-freezer, as Samsung produces both). Hope it's helpful :)
8helpful
RANGEMASTER FRIDGE /FREEZER WATER FILTER WARNING LIGHT
Hi i have a rangemaster s x s fridge freezer and the ice maker has stopped and now the whole fridge freezer has stopped. its 2 years old and out of warrenty can anyone help please with a suggestions as to whats wrong.
Water Filter
Open the fridge site, look up at the top right corner, half way to the back, you'll see the filter laying horizontally against the top of the fridge.
Push a button with the arrow to pull down the cover, you'll see the filter.
Twist the filter counter clockwise to remove it. My filter name is Puriclean II. Yours could be different.
4helpful
2answers
Reset after water filter replacement
Generally all you need to do is push and hold the filter reset button in for 3 to 5 seconds to reset it. However, even with the filter light on, it shouldn't stop the water flow as most of the time on most brands it is just an "idiot light" that is on either a timer based on number of days or on number of minutes the water has flowed through the water valve
3helpful
Samsung water filter rs21 dcns
Aug 06, 2008 • Freezers
Filter indicator on samsung side by side fridge freezer is on
3answers
American fridge freezer - sansumg rsh1dtmh
this samsung fridge freezer diy channel may help ckick here
also check this video ....http://www.youtube.com/profile?feature=iv&user=SamsungFridgeFreezer&annotation_id=annotation_526429
2answers
Samsung american fridge sn 188742bp100124K
The freezer temperature ok.
The fridge keeps freezing
1helpful
2answers
Water filter
The red warning light has to be reset manually - by pressing the Ice Type and Child Lock buttons together for 5 seconds. As for the taste, check the flow direction is correct on the filter and run a few litres of water off.
Top Samsung Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
