SOURCE: indesit machine won't start
on the bottom of the machine there is a panel made of plastic that may be removed to expose the waste filter.open the waste filter and check that the waste pump is not blocked as in the initial start up the pump is run if there is a problem with the pump the machine will not advance.
SOURCE: error codes for indesit front load washing machines
The F002 error codes relates to a motor problem. Do you know if the motor spins ?
SOURCE: Indesit Evolution 1600 WE 165 washing machine has stopped
its more the likely the water heater
SOURCE: Indesit washing machine WIXE127 switches off main fuse
Have you added anything else that is drawing juice on the same breaker?
If so try turning those off.
Hope this helped.Let me know by rating me or
for more help go to live chat.Thanks
Len West
SOURCE: indesit washing maching iwc125 no matter how high
If it truly 3 days old it, is still under warranty. Calll dealer have it fixed for free!!!
Many people use 40 degrees washes almost exclusively these days and the current trend is to use even lower temperatures to save energy ( Do you save as much as you think? Washing at 30 degrees ). Remember that a non-biological powder, doesn't work as well at lower temperatures so washing at low temperatures requires biological detergent for best results. It's also worth noting that bed bugs (or their eggs) are reported to be able to survive washing at lower temperatures and therefore it is recommended that bedding sheets should be washed at 60 degrees ( Related Whitegoodshelp Blog article: Bed bugs don't drown in the washing machine - but at least they get cleaned )
Also, (as mentioned in detail later) a regular 90 degrees maintenance wash is needed.
Washing machines now commonly suffer from a build up of a greasy deposit and bacteria that causes bad smells, rots hoses & door gaskets and blocks the pressure system causing overfilling or spin failure. An even more serious consequence of this problem is that the aluminium based drum spiders can be corroded by this grease and in serious cases can cause one or more arms to break. This is often fatal to the washing machine. Replace the door gasket with this part and wash the inside of the machine at least once a month with a GOOD HE washer cleaner like this one.
