It has a fresh xp operating system installed and only Intenet Explorer
Hi vsecrets,
need a little bit more information from you. First off, is your laptop 'seeing' the wireless card? I need you to check the device manager to see to see if there's a yellow exclamation point by the NIC and to check the driver version for it. If the driver IS missing, you need to go the manufacturer's site and download it. If it is there, still make sure there isn'[t a newer version. Let us know what you find.
SOURCE: cant get my unit to connect at wifi hotspots
Have you connect/pair your laptop with hotspot/access point ?
Before going into internet explorer, you should connect to the access point first.
SOURCE: Averatec 3200 Series Laptop
If you have access to another machine you can create a disk to fix the ntldr issue. Please see the following website. http://www.tinyempire.com/notes/ntldrismissing.htm
SOURCE: Acer D150 Netbook - I get a good WIFI signal but
go to my network place then go to local area connection logo and right click on it then go to propeties after that u will see a window crew down to TCP/IP once u are thr click on properties to ur left then fill in the code after than click okay and make local area connection your default connection. thats it u are done
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
