SOURCE: I need a Manual for my sewing machine PLEASE
I can probably print out a copy of all my instructions for you and send them to you. Myself I am having problems with my thread breaking every time.As soon as I start sewing my top threat breaks. I dont know whats doing it. My manual isnt helping me.My email is [email protected] write me and i will send you a copy of the manual.I have euro-pro model 385x and I have the manual. Let me know. Peggy.
SOURCE: MANUAL FOR BROTHER INDUSTRIAL SEWING MACHINE DB2-B755-3
Go to brother.com . From there you will need to enter the model number and serial number to get the file for free good luck
SOURCE: manual from brother listed sewing machine
I believe these are the UL code and serial number. If there is a display band of decorative stitches on the front of your machine look on the bottom right of that panel. If the number there is a VX-920 there is no manual available for it BUT you can use the manual from the VX 970 which IS available. Do a search for that model manual in Spanish and you should find one.
SOURCE: What is the Brother Pacesetter NX-200 F4 machine error, and how do I fix it?
You will receive F4 error message, when there is a problem within the unit, internal circuit board.
Your Brother Sewing machine need to be service.
Good Luck.
SOURCE: brother pe-770 f05 speed sensor error - How to fix?
F05 error, speed sensor. I fixed successfully 2 of those. Speed sensor is located on a small board, under a protective plastic, located over the main front board. Remove front panel and bobin winder assembly. Remove the 2 screws of the small board. Remve CAREFULLY the small bord. Under, on the main shaft, are located the needle positionning sensors and the wheel of the speed sensor (left wheel on the shaft). The speed sensor is located on the board itself, it's very small. Clean carefully both the wheel and the sensor with Q-Tips and alchool, reassemble the whole thing and it should restart.
While U are there, take a thin nozzle oiler and lubrificate all the suppots of upper and lower shaft, all the needle bar mechanism and rotary hook central shaft and gears WITH VERY THICK oil. Needle bas assembly is the most critical point. I have 14 of those machines, almost all of those seized there before I learn how to lubrificate it. Also seized on the bottom shaft and on rotary hook pin
