w
willie Posted on Jun 16, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
More details about problem the Panasonic SC-AK22 : When I press the power button on, instead of the display showing "Hello" it shows "F61" and goes off. No matter how many times
Grubhead
Level 3:
  • Panasonic Master 5,755 Answers
  • Posted on Jun 20, 2018
 Grubhead
Panasonic Master
Level 3:
Answers
5755
Questions
Helped
1661679
Points
11417
Bad news the main power amp has failed.
The good news is that the service manual is online and it's free.
You will need to read the manual and find IC500, which it says is an RSN3502C.
Panasonic SA AK22 Service Manual Page 126
5 Related Answers
Anonymous
  • 130 Answers
  • Posted on Apr 10, 2006
SOURCE: Panasonic SC-PM08 shuts down error F74
Would be cool if that display means you have #74 fuse blown. Maybe its for the amp output to the speakers? have you tried the speakers on another system? could they be blown? Is there anything in the manual about the error?
Anonymous
  • 4234 Answers
  • Posted on May 15, 2008
SOURCE: Panasonic SA-HT940
F61 is a problem with the output amplifier pac. It is the equivalent of "protect" mode. The output pac needs to be replaced. I'll look up the part number for you.
Dan
appman67
appman67
  • 33 Answers
  • Posted on Sep 21, 2008
SOURCE: f61 fault
Although the Panasonic Home Theater systems are great when they work properly. If your machine displays the "f61" error message, it's likely to be little more than a paper weight for the average person. The inner workings of the machine are rather complex to disassemble for diagnostics. And can take several hours to check all the components. The best advice I can give you is to sell the machine on e-bay as a broken item. If you offer shipping you can get more money for a complete system (speakers & all).
Anonymous
  • Posted on Apr 14, 2009
SOURCE: SC-BT 100 Error Code f61
Had the same problem. Found that the code refers to the cooling fan. Could be that the fan is dusty or not running when the system starts up. I removed the fan with the two screws and reseated the plug. Make certain that the short, black wire (that seems to go to nothing) is securing the plug to the board.
Anonymous
  • Posted on Feb 12, 2010
SOURCE: Panasonic DMR-ES46V shows F60 Error
I have same problem with es40v - f60 error with no response to troubleshooting protocol. This machine also was used very little & also has a history of turning itself on. Panasonic used to make high quality products. A shame that their products are no longer trustworthy. I can understand that machines break - i'm very frustrated to learn replacement parts are not available. Guess i need to re- think brand loyalty.
Halo,just some help pls...my Panasonic SA-MAX5000 just shows F61..I have read about the fans that could be the problem..but botH are running....
Hello Hendrix, I pass the list of reasons why your Panasonic SA-MAX5000 tells you F61, this information is taken from The Community ELECTRONICOS.com
F61 The DC DECT circuit of the "micro" detected an anomaly. * See: Note 1 Source: www.comunidadelectronicos.com
* Note 1: The error code F61 is one of the most frequent and its origin can be due to different causes. This occurs when the "micro" (IC system control) detects a variation in the reference voltage of the pin called DCDET. This voltage is 5 V. Through this pin (in some models are two: DCDET1 and DCDET2), the micro monitor the presence of DC voltage (direct current) in the speaker output, in addition to the voltages (+ and - ) power supply of the output stage and the other voltages provided by the source (5, 9, 15V, etc.) A short circuit or excessive consumption at any stage of the equipment, resulting in the absence or fall below the normal value, of any of the voltages of the source will cause the reference voltage of the DCDET pin to drop below 5V, causing the micro to turn off the equipment and present the F61 code on the display. The same happens if there is a direct voltage (DC) in any of the outputs to the loudspeakers, of the power stage. In most of the cases that the error code F61 is presented, it is usually due to problems in the power stage. For this reason, it is advisable, as a first step, to check this stage, completely disconnecting the integrated output circuit and testing the equipment again. If you turn on normally, without presenting the error code, it is necessary to replace the integrated one. If after disconnecting the power integrated, still continues to present the code F61, it is necessary to start the checks on the pin or DCDET pins of the "micro" and trace the cause from there. The same could be due to some defective component in the same DCDET circuit, or, because any of the supply voltages is absent or below normal. Not detailed here, specific data on identification of components or voltages of the circuits, because these vary depending on the model. But in all cases the reference voltage in DCDET is 5V The DCDET pins of the "Micro", vary according to the model, for example: in models SA-AK15, SA-AK18, SC-AK27 (and others) pin 32 in models SC-AK22 / 33/44/55 (and others) pins 33 and 34 If it is determined that error F61 is due to any of the voltages absent or below normal, obviously the cause in the corresponding circuits. In summary: A fault in the output stage or any of the power circuits, including voltage regulators, diodes, capacitors, etc., may cause the F61 error code to appear. A "locked" mechanism can cause the consumption of a motor to be excessive, reducing the corresponding voltage due to the overload and also producing the indicated code. As indicated above, the causes can be diverse, but starting the search, from the pin or DCDET pins of the micro with the help of the diagram, you can locate the source of the problem, in order to solve it.
I hope it will help you find the solution
Greetings Franco Dosil
Hola Hendrix, te paso el listado de motivos por el cual tu Panasonic SA-MAX5000 te indica F61, esta informacion la tome de La Comunidad ELECTRONICOS.com
F61 El circuito DC DECT del "micro" a detectado una anomal?a. * Ver: Nota 1 Fuente: www.comunidadelectronicos.com
* Nota 1: El c?digo de error F61, es uno de los que suele presentarse con mayor frecuencia y su origen puede deberse a diferentes causas. Esto ocurre, cuando el "micro" (IC system control) detecta una variaci?n en el voltaje de referencia del pin denominado DCDET. Dicho voltaje es de 5 V. A trav?s de ese pin (en algunos modelos son dos: DCDET1 y DCDET2), el micro monitorea la presencia de tensi?n DC (corriente continua) en la salida de altavoces, adem?s de los voltajes (+ y -) de alimentaci?n de la etapa de salida y los dem?s voltajes proporcionados por la fuente (5, 9, 15V, etc.) Un cortocircuito o consumo excesivo en cualquier etapa del equipo, que produzca la ausencia o ca?da por debajo del valor normal, de alguno de los voltajes de la fuente, har? que el voltaje de referencia del pin DCDET baje por debajo de los 5V, haciendo que el micro apague el equipo y presente el c?digo F61 en el display. Lo mismo ocurre si existe tensi?n continua (DC) en alguna de las salidas a los altavoces, de la etapa de potencia. En la mayor?a de los casos que se presenta el c?digo de error F61, suele deberse a problemas en la etapa de potencia. Por ello, es recomendable, como primer paso comprobar esta etapa, desconectando totalmente el circuito integrado de salida y probando nuevamente el equipo. Si enciende normalmente, sin presentar el c?digo de error, es necesario reemplazar el integrado. Si despu?s de desconectar el integrado de potencia, aun continua presentando el c?digo F61, es necesario comenzar las comprobaciones en el pin o pines DCDET del "micro" y rastrear desde all? la causa. La misma podr?a deberse a alg?n componente defectuoso en el mismo circuito DCDET, o, a que alguno de los voltajes de alimentaci?n est? ausente o por debajo de lo normal. No se detallan aqu?, datos concretos sobre identificaci?n de componentes o voltajes de los circuitos, debido a que estos var?an dependiendo del modelo. Pero en todos los casos el voltaje de referencia en DCDET es 5V Los pines DCDET del "Micro", var?an seg?n el modelo, por ejemplo: en los modelos SA-AK15, SA-AK18, SC-AK27 (y otros) pin 32 en los modelos SC-AK22 / 33 / 44 / 55 (y otros) los pines 33 y 34 Si se determina que el error F61 se debe a alguno de los voltajes ausente o por debajo de lo normal, obviamente habr? que rastrear la causa en los circuitos correspondientes. Resumiendo: Una falla en la etapa de salida o cualquiera de los circuitos de alimentaci?n, incluyendo reguladores de voltaje, diodos, condensadores, etc., puede ocasionar que aparezca el c?digo de error F61. Un mecanismo "trancado" puede originar que el consumo de un motor sea excesivo, reduciendo el voltaje correspondiente debido a la sobrecarga y produciendo tambi?n el c?digo indicado. Como se indico anteriormente, las causas pueden ser diversas, pero comenzando la b?squeda, desde el pin o pines DCDET del micro con la ayuda del diagrama, se puede localizar el origen del problema, para as? solucionarlo.
Espero te sirva para encontrar la solucion
Saludos Franco Dosil
https://www.comunidadelectronicos.com/
https://data2.manualslib.com/pdf6/126/12518/1251783-panasonic/samax5000pn.pdf?0b037fce2e01f8dd9f10def6145c9438&take=binary
16helpful
7answers
AFTER A FEW SECONDS MY SYSTEM SHUT DOWN AND SHOWS ME F61 ON THE SCREEM
  1. AFTER A FEW SECONDS MY SISTEM SHUT DOWN AND SHOW ME F61 ON THE SCREEN
3helpful
3answers
Repeated F61 fault code on Panasonic Home cinema system Model: SC-HT990 Is it the fan in the sub woofer?
Hello
F 61 error means the failure of FAN
most probably dust in the fan made it to stop working so clean the dust and connect the fan to an external supply of 12v(using red and black wire) for 5 minutes and reconnect it to the unit otherwise replace the fan with new one.
Surely this will solve the problem.
Kind regards
Andrea
1helpful
2answers
Press power it shows f61 instead of what it should show
You need to open the back of the system and change the fuse located on the right side of he panel. you can go to Radio Shack and get the fuse for $1.99.
2helpful
SA AK200 does not appear to turn off completely
HiFi system actually turned Off when you press power button and display of hello, heavy, vocal etc is demo mode of this system and it activates when unit goes to power off.
You can change its settings like not to show demo mode etc and this procedure is described in owner's manual.
Thank you.
Getting F61 in Display of Panasonic SC-HT700
I have gotten the f61 error code on my SC-HT700. No idea what the problem is.
6helpful
3answers
F61 fault
9helpful
3answers
Panasonic SA-AK600
Try to power on the unit without the speakers connected. If it works normally without the error showing, then a speaker wire maybe shorted or a speaker defective. If the error F61 is still there, then most likely the Regulator IC is defective in the unit.
4helpful
Panasonic SC-HT75 Home Theater system
with the unit switched on press and hold the stop button and press the power button once. if that doesn't work then try it with the play button.
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
