Someone has pressed the clerk button so they have logged out of the register. you need to enter an operator's PIN number and press the clerk button to log in. if you have forgotten the PIN, you need to use your programming manual to create new login codes. Not sure about stock issue. probably a bad stock entry/ overflow. haven't used stock system on these before. If you need more info, checkout tech is best place to get manuals for this model
https://the-checkout-tech.com/manuals/cashregisters/Sharp_UP-600_UP-700_programming_manual.html
https://the-checkout-tech.com/manuals/cashregisters/Sharp_UP-700_operation_manual.html
SOURCE: Sharp LC-32P70E TV: EPG suddenly not showing
hello, this sounds more like a cable or satelite problem. hame you tried reseting your cable or sat box? usually when you reset the box it will download the guide again...
SOURCE: NEED TO ASSIGN CLERKS TO KEYS ON CASIO TE4500F.
UH just tell each clerk which key is theirs....
SOURCE: AEG 72640 stopping mid-cycle no error code showing
I have the same problem with my Oko Lavamat 74639 Update. I've tried changing the vacuum sensor, but no luck.
Did you get your fixed?
Olafur
SOURCE: We have the Verifone VX510.
call the verifone number on the machine try plugging it in to another phone line
SOURCE: SHARP POS TERMINAL UP-3000 SERIES
I have a Sharp POS terminal UP-3300 till.
3 till in total the mailn till No 1 is ok No2 is coming up POWER OFF and will not let me log on. No3 is coming up SYSTEM CLOSED can you help me
