SOURCE: HTR-5930
To get audio from your TV through your AV receiver, please connect stereo audio cables from an available AV input on the rear of your receiver such as D-TV/LD or CBL/Sat. Then refer to your TV owner's manual for more information about audio output to an amplifier. You may have to turn off the internal TV speakers in order to get any output from the TV into the AV receiver.
SOURCE: No video signal on Yamaha HTR 5930
On , HTR-5930, composite inputs are routed only to composite outputs. The same happens to component input. You can't see video from V AUX if your TV is hooked-up on component output. Also, check if you connected correctly GREEN, BLUE AND RED on both receiver and TV SET.
SOURCE: Yamaha HTR-5750 no sound when I turn to the DTV/Cable setting
If you are not getting sound on "Any" input except "multi channel" you have a bad DSP chip in the receiver.In short, you need a new receiver, it's a 500.00 repair. If you get sound on "All" inputs except "DTV/CBL" You need to get into the main menu of the Yamaha and select audio, toggle to input, then DTV/CBL and select "Auto". If you still do not get audio, it would be due to the version of HDMI software in your receiver. If it's under warranty, Yamaha will update hardware and software for you at N/C. If it's out of warranty, use digital coaxial or optical as your audio input for TV and run your HDMI directly to the TV. (The repair for this too would run 250-350) I hope I've covered all the possibilities. If you need further help, post a comment and I can help you more.
Testimonial: "thanks for the info boss it's greatly appreciated"
SOURCE: Yamaha HTR-6230 receiver set up w/HDMI no sound
BD and DVR hooked up to the receiver and from the receiver to the TV right? If yes: Your receiver set to pass sound trough to the TV, if you want sound from the home theater setting has to be changed.
SOURCE: Yamaha amplifier HTR 5930 is not sending sound to
... Incorrect setup; incorrect speaker definition; speaker B selected instead of speaker A.
Testimonial: "Thank you. A simple solution for a non technical person."
