Computers & Internet Logo
A
Austine Gilberts Posted on Jun 15, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The access ibm button on thinkpad t43 is not working after i changed hdd
goneforever.
Level 3:
Top Expert:
  • IBM Master 14,531 Answers
  • Posted on Jan 18, 2022
goneforever.
IBM Master
Level 3:
Top Expert:
Answers
14531
Questions
0
Helped
3263791
Points
66315
New boot HDD
means OS is gone
reload the OS fresh.
5 Related Answers
tom19511
Thomas Christopher
  • 1601 Answers
  • Posted on Jan 13, 2008
SOURCE: ibm thinkpad g40 support
Your laptop comes with a recovery partition. You can reinstall the drivers for this through it.Your documentation will show you how.
ItWillBoK
ItWillBoK
  • 108 Answers
  • Posted on Dec 25, 2008
SOURCE: Is there a way to master reset the IBM T43 Thinkpad
No it's not possible to do it with just a button or replace it to factory settings.
The T43 Comes with WinXP or OS/2 Warp or Windows 2000 Pro.
If you wanted to reset it you basically would have to format the harddrive.
You can get a older version of WinXP which is still supported by microsoft or either that you can format it and sell it without a operating system.
Or you can add/remove items you installed and remove personal info delete pretty items much within windows itself.
Happy Holidays
Aseem
  • 68 Answers
  • Posted on Sep 30, 2009
SOURCE: No Sound on my IBM t43 Thinkpad
all hardware requires a driver
driver is an information file that tells the operating system how device works
without the driver the device cant work
when you reformatted you must not have installed sound drivers
here is a link to Windows XP version of the sound drivers of your laptop
http://www-307.ibm.com/pc/support/site.wss/license.do?filename=mobiles/1ya210ww.exe
download it
install it
reboot
and you will have sound
if you have a different operating system than windows XP, tell me and i will give you link for that
Anonymous
  • 37 Answers
  • Posted on Oct 12, 2009
SOURCE: IBM THINKPAD T43. I can find the switch for my ibm thinkpad T43
Are you sure you have a wire card installed? If so, then try this:
  1. Right-click the My Computer icon and select Properties.
  2. Click the Hardware tab and press the Device Manager button. The network card should appear under Network Adapters.
    Note: If the card has a exclamation mark over a yellow background, then this is an indication that the card is experiencing a problem. Go to Driver download step 5.
  1. Verify that the radio is enabled.
    It is possible to disable the transmitter of the wireless card without Device Manager showing any problems.
    Note: Follow the instructions provided to enable wireless card.
    • Most wireless cards will put an icon in the system tray (the line of icons in the lower right corner of your screen). Right click this icon and it may have a menu option to enable/turn on the wireless radio.
    • Some systems come with a Wireless Radio switch to disable the wireless radios. The wireless radio switch is usually located on the front side of the machine. If you are having difficulties with wireless connections, make sure the Wireless Radio switch is set in the On position.
  2. Check for association to an Access Point.
    If you double-click the previously mentioned system tray icon, the configuration utility of the wireless card will appear. This utility will be able to show the status of the wireless card, showing what channel the card is using and what signal strength is being received. It may be difficult to maintain a connection if signal strength is low due to either interference or distance. For example, interference can be caused by 2.4GHz cordless phones, other Access Points in the area, and physical structures such as load bearing walls or metal partitions.
    Note:
    The utility can be used to configure the wireless card settings, but if using Windows XP Zero Configuration or Access Connections, you will need to use those programs to actually configure the wireless card as they will overwrite the setting of the utility.
Anonymous
  • Posted on Jul 22, 2010
SOURCE: IBM thinkpad T43 wireless lan problem
I solve wifi problems on IBM Thinkpad T43 with this driver : http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=18404&lang=eng
It does not boot anyway on hdd or cd, i have ibm screen one time out of ten ; IBM T43 PENTIUM M 1.86GHZ/RAM 1Go/HDD 40.Go BIOS already updated with latest version from lenovo
restart the system and continue to press F2 ,so tht u can enter into the BIOS settings,change the boot option to cd/dvd...if still the problem persists clean your dvd case once or continue with another cd/dvd...
Ibm thinkpad t43 windows xp it has ad-block from
Hi, During the boot at the THINKPAD SCREEN press the Thinkvantage key ( Blue button ) it will launch rescue and recovery and allow you to reboot factory. This only works if you did not corrupted/deleted the rescue and recovery hidden partition on the HDD. Otherwise you will need the rescue and recovery CD to proceed. IBM/Lenovo support should be able to provide you the CD. Might be a defective hdd aswell, in this case to make sure you can run a DFT test, www.google.com -> Look up for " Test DFT " ( Drive fitness tool from hitachi, will make an hardware diag if hdd failure - error code 0x00 = everything fine, other code = Issue - You can look up for accurate code explanation on hitachi website ) thanks and have a nice day J-
Ibm t43 compatible hard drive
with ibm when u change new hard disk you much find ibm hadr disk support for laptop, if another type u much run fix hdd
you go here to download soft to do and search hdd supported
http://www-307.ibm.com/pc/support/site.wss/MIGR-62282.html.
2answers
BIOS self-set Password after upgrade/HD Install
http://sodoityourself.com/hacking-ibm-thinkpad-bios-password/
try this if you can do  but i am not sure.  i am good on electronic things but its hard to do that. its only way.
1helpful
2answers
Hard drive failure on IBM T43
I have a ThinkPad T43,
Now it's hard drive is broken so when i change the new hard drive Hitachi 160GB it display the message as below.
Could you help me to terminate this error message.
2010: Warning: Your internal hard disk drive (HDD) may not function correctly on this system. Ensure that your HDD is supported on this system and that the latest HDD firmware is installed. Press <Esc> to continue
I try to update firmware of the harddrive but still appear the message the same.
Top IBM Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
