Question about Jamo Audio Players & Recorders
What is the best setup for the Jamo DS7 system in a bedroom?
Oil mixture and type 1972 RD 250
i suggest any good synthetic oil at 50 to 1.. remember when that was built they used straight 30weight. modern oils are better for sure. does it not have an oil pump??
May 30, 2018 | Motorcycles
Need to replace 5.5" woofer in Jamo S426 floorstanding speaker
contact maplin electronics they are really good at replacement units.
Jun 30, 2012 | Jamo S426HCS3 5pcs Home Theater Speaker...
I was given a Jamo sub 1810, but have no instruction manual. I'm trying to hook up to my Pioneer HTP-2500 home theater system. What would be the correct way? Also if you could help me with the setup,...
Find it here...
http://www.jamo.com/na-en/support/owners-manuals/
http://www.jamo.com/images/download/779.aspx
The Jamo is self-amplified and accepts Line Level input ONLY.
The HTP-2500 receiver drives a subwoofer directly with SPEAKER LEVEL output only and does not have a volume-controlled output for driving externally-amplified devices.
May 21, 2011 | Jamo SUB 1810 Subwoofer
Help how to best connect sky hd and PS3 to a Jamo
you will have to use a component cable or optical lead from your ps3 to the jamo and sky hd to be connected via scart.
for best image,buy an HDMI CONNECTORS switch that will allow you to run many HDMI TO IT and from the switch you only need one to the tv so the jamo still output to the tv.
remember that you will have to get an automatic one so that it can select when you are using each element.
Mar 04, 2009 | Jamo DMR 60 DVD Player/Receiver
Problem with jamo dvr50 plays dvd's will not play C.D's
If cleaning the laser lens assy does not take care of the problem you will have a defective laser assy.
Dec 17, 2008 | Jamo DVR-50 System
I have no amp for jamo 1060 sub
Dual Voice-Coil
The unique Dual Voice-Coil design allows both left and right channel sound from just one speaker. Simply hook up both the left and the right channels to the special terminals on the speaker. Hook up one channel only, if the speaker is to be used in a conventional stereo set-up.
I found this on jamo site hope that will help you
Mar 15, 2008 | Jamo 1060 SW Speaker
Volume
It's the receiver, same prob here. The level of bass through the sub is negligible too. So my guess is it's either related to the crossover or the passthrough in general.
Looking for a missetting or workaround.
Mar 04, 2008 | Onkyo TX-SR605 Receiver
Jamo DVR-50 Problem
had same problem told power supply unit is u/s £153 all in to fix it , gonna get new player , other probs telephone Telefringe 01373 462598. hope this helps someone.
Nov 22, 2007 | Jamo DVR-50 System
69 people viewed this question
Top Jamo Audio Players & Recorders Experts
 Grubhead
Grubhead
rjivaro
Robert Rankin
Are you a Jamo Audio Player and Recorder Expert? Answer questions, earn points and help others
