Sreejith Poolakkal Posted on Jun 15, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
MY ONKYO RECIVER IS GOING TO STANDBY MODE.ANY SOLUTION TO CLEAR THE COMPLAINT.
Mark Mathis
Level 2:
Habit-Forming:
New Friend:
  • Expert 106 Answers
  • Posted on Sep 09, 2019
Mark Mathis
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
106
Questions
0
Helped
68793
Points
206
Hello
Your AVR is in protection mode
Check Speaker cables if there is a short circuit or defected speaker. can also do the same thing.
If non of the above.
you need to service the AVR .
Good luck
4 Related Answers
Anonymous
  • 752 Answers
  • Posted on Sep 15, 2007
SOURCE: Onkyo TX-DS474 Receiver shuts down after Standby mode.
It's going into a protect mode. The amp is probably shorted out. Disconnect the spkrs and turn it on. If it still shuts off, it's the amp, if not, it's the spkrs.
Anonymous
  • 8546 Answers
  • Posted on Jul 06, 2011
SOURCE: onkyo txsr806 keeps on going into standby
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Testimonial: "i will try that . many thanks"
Anonymous
  • 8546 Answers
  • Posted on Jul 08, 2011
SOURCE: hello. I have some problems with
Check for loose speaker connections at the speaker as another possible root cause for intermittent shutdown.
gopakumarg43
  • 76851 Answers
  • Posted on Jul 19, 2015
SOURCE: LA76931A DE 57V9 6EAO7 IC USING BPL TV IS POWER ON THEN GO TO STANDBY MODE..ON TIME PICTURE IS CLEAR BUT TV go to standby?what is solution avoding protection mode?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Search the site by type in the brand name to your device, in the "Search box at the top right of the display window".
Onkyo txsr313 receiver working mode but stuck, cannot working switches and remote?
https://www.youtube.com/watch?v=gfJEw-VlpWY
Hold the "VCR/DVD" button while pressing the "On/Standby" button, and the receiver should enter "Standby." Turn it on again by pressing the "On/Standby" button. Bear in mind that this will clear all the presets and other settings - but it may be those settings that are causing the problems.
https://www.techwalla.com/articles/how-to-troubleshoot-onkyo-receivers
Im Need Help Resetting My ONKYO TX-SR6O3X RECIEVER Its By Itself Or The Owners Manual to Help me reset it
Resetting the AV receiver to its factory defaults To reset the AV receiver to its factory defaults, turn it on and, while holding down the [VIDEO 1] button, press the [STANDBY/ON] button. "CLEAR" will appear on the display and the AV receiver will enter Standby mode
How to fix Onkyo TX SR 303 when it says phones engaged but no phones are not plugged in
Hello, I suggest a reset of the receiver. Please see the procedure below. Thank you, Onkyo USA.
To reset the AV receiver to its factory defaults, turn it on and, while holding down the [VIDEO 1/VCR] button, press the [STANDBY/ON] button. "Clear" will appear on the display and the AV receiver will enter Standby mode.
Have noise on left back speaker channel of onkyo 606 blocking sound from movies etc
Hi Brendan, have you swapped the speaker from the left channel to the right one so that we can be sure that it is not the speaker? You can also try a hard reset:
To do the reset you need to turn the receiver on, then on the front panel of the receiver press and hold the "VCR/DVR" button while doing that press the "STANDBY/ON" button. You will see the word "Clear" in the display screen and the receiver will go into standby mode. PLEASE UNDERSTAND THAT YOU WILL LOSE ALL YOUR AUDIO & VIDEO ASSIGNMENTS ON THE RECEIVER PLUS YOU WILL LOSE ALL YOUR SPEAKER CONFIGURATIONS, SPEAKER DISTANCE AND ALL LEVEL CALIBRATION SETTINGS. YOU WILL ALSO LOSE ANY PROGRAMMED RADIO STATIONS IN MEMORY. Once the receiver goes into standby mode turn it back on and go thru the setup menu for all custom settings.
If you need further assistance please email me at [email protected], Thanks,JT
How to reset factory settings for onkyo tx-sv303pro without the remote
To reset the AV receiver to factory default ,turn it on and, while holding down the (VIDEO 1/VCR) button, press the (STANDBY/ON) button "Clear" will appear on the display and the AV receiver will enter Standby mode. :)
Onkyo txsr806 no video thru hdmi from unit to tv
HI,
Fist of all you have to check the HDMI cable. It should be 1.3a version.
Another thing is ONKYO TXSR806 is capable of outputing HD video (1080p) at its HDMI output By upscaling. If your tv is not a Full HD one then it will not be able to show the video.
Do one thing Reset the ONKYO to factory default. While in standby mode Press and hold the VCR/DVD Then press the standby button "Clear" will show upon the screen.
Ajin
I have SR 307 onkyo A/V receiver home theatre system. the remote control has stopped working. i checked with a local dealer and that the remote is okay and something has wrong in the receiver,
Did you check the remote with another Onkyo system at the dealer ??. If its OK try resetting the system. Remember you will loose all your stored presets ( FM and customized settings ) and the Amp will go back to factory settings.
While in standby mode hold down the DVD button and press the Standby/On button., the display will show Clear and the Receiver will go into standby mode. Turn it on and try the remote once again.
My reciver just shutdown then went into standby mode. Will not power back on. How do I fix this problem?
Wow, where to start. Just off the top of my head with 50 years experience working on electronics I would check all the final transistors for shorts. This is the weakest part of the unit and where I find all my problems. If the power supply was bad odds are you would not have standby. Check them out and let me know.
hardrocko
What do you mean by standby mode? Do you hear the power relay switch clicking constantly, or does it just click once and turn off? In any case, it could be a faulty power relay. I just sent in my TX-SR806 for warranty repair recently, and it ended up being just that.
Onkyo ts595 goes into protect mode with volume increase
Hold the VCR/DVR button in and press the ON/OFF Standby button. The display should briefly read CLEAR and then the unit switches off. If that clears protect mode, you'll need to redo the Audyssey and configuration setup as these will have been cleared by the reset.
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
John
John
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
