I have cleaned both screen filters to insure clear water flow. Nothing helps. What can I do? We have unplugged the machine to reset, but does not help.
SOURCE: Washing machine wont stop filling up
see if the water coming in is hot or cold by turning the water faucets off and on to see if one fills and the other dont and replace the valve
SOURCE: Filling With Water
This is probably a control board failure, which should be replaced by someone familiar with them.
If you are handy, you can do it yourself.
If you need assistance, let me know.
SOURCE: Eurotech washer Leaking water front detergent drawer
I'm not familiar with your machine but usually there are nozzles above the soap drawer which squirt the water on to the detergent compartments at the appropriate times . If you can take out the soap tray have a look to see if the nozzle bit has come loose and is pointing towards you...also check that the outlets from the soap tray are not clogged with...soap.
Failing that, you could partially turn off the water supply to the machine so the pressure is reduced. Sure it will take longer to fill, but you won't get so wet.
Hope this helps. If this "fixes ya", I'd appreciate a rating for my reply, If not, please delay the rating and add a comment with any extra info you have and I will try to think of something else.
Thanks, D
SOURCE: Hotpoint Aquarius WT540 washing machine. will not fill with water
Sounds like a timer switch malfunction.
SOURCE: Kenmore 500 top load washer starts to fill withwater then stops
This is commonly caused by a lid switch malfunction. If the washer fills, agitates, then stops at the rinse and won't drain, or if the washer does an initial fill, then stops, this is a symptom of a lid switch malfunction.
The following link explains how to access and/or replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug.
On some models, the lid switch is located under the top casing by one of the lid hinges. You will know if you if you have this type of switch, because It does not have a lid strike and the small hole on the right hand side of the wash tub will not be present. This switch is actuated (toggled) by a rod on the lid hinge. With this type of switch, if you locate it and it can be toggled by hand, you may only need to adjust the actuator by bending it slightly.
If the lid switch is found to be defective, it can be purchased at any of the following websites:
searspartsdirect.com
applaincepartspros.com
pcappliancerepair.com
repairclinic.com
The average price is $25 to $35. Prices vary between these sites, so shop around for the best deal.
This is a very simple repair, but if you still have questions, please let me know. I hope this helps you.
