SOURCE: MAYTAG MDE7057AYW NO HEAT
CAN YOU USE A MULTIMETER? IF SO, OHM THE THERMAL FUSE. IF THIS IS OPEN REPLACE IT.
SOURCE: The heated dry and clean lights flash together
I had this same problem. I read on another blog that the manual recommends that you turn the power off to dishwasher. When you turn the washer back on, the lights still flash but then push the off button. The lights stopped flashing.
SOURCE: maytag electric oven - MER5770AAQ. lower heating element not work
Hi, Unplug the oven and remove the element to test it. Check the element and see if there is continuity. If the element is open, replace it. It can be bad even tho it doesn't appear bad.
I hope this helps you.
Vic
