Vacuums Logo
Justas JUSTAS Posted on Jun 14, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Karcher puzzi 8/1c, stopped spraying, low sound of motor (sprayer). Who can help to fix it?
I am using Karcher puzzi 8/1c, and when tank is empty and I turn on sprayer it has loud sound but while I was working with it (cleaning it had half tank of water) ,It stopped spraying water and the sound has gone, only silent sound (when I turn on sprayer). What could it be?
Steve Pack
Level 3:
  • Karcher Master 7,128 Answers
  • Posted on Jun 14, 2018
Steve Pack
Karcher Master
Level 3:
Answers
7128
Questions
Helped
2274152
Points
27960
Replace piston seals and valves.
5 Related Answers
A
Anonymous
  • Posted on Apr 19, 2008
SOURCE: Bissell ProHeat Clear won't spray from floor nozzels but it does stray from hand cleaner
I agree - just got done fixing 1 of these tonight. The heater plugs up and no spray. Easy Fix, the heater is in the handle and pretty easy to remove. then a straightened paper clip and a blast of air and you should be go to go.
Anonymous
  • 1673 Answers
  • Posted on Jun 17, 2008
SOURCE: will not **** up the water
Make sure that the lid on the recovery tank is locked down all of the way around. Sometimes the back side isn't locked in. If the lid has a foam filter on it, make sure it has at least a 1/4 in. gap from the top of the filter to the top of the tank. There also is a filter from the bottom, it has a red frame, pull it out far enough to clean it. Also some of these had a duct that sits in front of the recovery tank, if not there, then no suction.
Anonymous
  • 14 Answers
  • Posted on Mar 06, 2009
SOURCE: Karcher Press & Ex 800
The water pump is not working or the pump line is blocked. Check the pupm hose, if ok replace water pump
Anonymous
  • 3 Answers
  • Posted on Nov 27, 2009
SOURCE: The sprayer seems to have stopped spraying water,
I have had the same problem. Usually it's the soap, which has gummed up. I have soaked the head in hop water and this has taken care of the problem. I make sure to do this after I use it, and at times, filling the tank with clean water and run this through to clean out any residual detergent.. Hope this helps.
Anonymous
  • 43501 Answers
  • Posted on Sep 30, 2010
SOURCE: my bissell stops spraying water, carpet not wet
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
rtetrhgd
Karcher puzzi 10/1 carpet & upholstery cleaning maching not working in suction mode.
It sounds like you are having some issues with your Karcher Puzzi 10/1 carpet and upholstery cleaning machine. Here are a few things you can try to troubleshoot the problem:
  1. Make sure that the hose is securely attached to the machine and that there are no kinks or blockages in the hose.
  2. Check the filter to make sure it is clean and not clogged. If the filter is dirty or clogged, it can reduce suction power.
  3. Check the solution tank to make sure it is properly seated and sealed. If the solution tank is not seated correctly, it can cause problems with suction.
  4. Make sure that the machine is turned on and that the switch is set to the "suction" mode.
  5. If the problem persists, you may need to take the machine to a Karcher service center for further diagnosis and repair.
I hope this helps! Let me know if you have any other questions.
Karcher Puzzi 8/1 C got white smoke
Possibly water went into the motor are a new motor will now be required. Either way the motor sounds past its best.
7helpful
2answers
Cant get my soap dispenser hose working on my karcher winner 10, any suggestion?, lost my instructions manual so dont know weather i need to be doing anything for it!
If you have not yet found a solution, then here are some steps to take.
1. The soap dispenser only works on low pressure!!!!!!! So you have to REMOVE the high pressure Sprayer so that all you use is the Trigger Gun without the Extender.
2. Pull out the thin Plastic Hose with the filter attached in the end, and insert into your container of detergent.
It will only splatter the detergent over the area you want to clean, so you will then need to REATTACH the SPRAYER into the hand gun to work with the soap to lather, clean and spray of till clean.
This seems to be the way the system works on this model......also known as K2.36M (AU) in Australia or (EU) in Europe on the Karcher.com.au site then Service then Manuals. or on the link below.
Hope this helps any of you who has misplaced their Owners Manual just like I did and had a great problem trying to find a link as Karcher doesn't recognize the Model No: as Winner 10 or 11.
Cheers, Luke
1helpful
Not wanting to spray shampoo/water piece of ****!!!!!!!
Capt. Obvious fixes: Of course make sure there's clean water in the bladder of the water tank and soap in the soap tank, and make sure the dial is set to Floor Cleaning, not Tool Cleaning or somewhere in between.
Sometimes an air pocket inside the machine (even a new one) keeps water from flowing, until you reprime the Bissell's internal pumps. To prime the pumps the easy way, turn it on, then press, hold, and release the water-and-soap trigger a few times, waiting a few seconds each time.
Still nothing? Prime it the slightly harder way. Separate the two water tank pieces. Only have the base tank filled and mounted on the Bissell without the piece that sits atop the tank. Turn it on. Kneeling on the floor in front of the Bissell, reach up and press the soap and water trigger at the top of the Bissell's handle and hold it in as if you wanted water to go through. On top of the water tank is a plastic grommet hole about 1 inch in diameter, through which you pour water to fill the tank. Seal that hole with the flat of your hand. You'll feel just a bit of suction. Lift your hand up and down a few times, a few seconds apart. Release the trigger and repeat a few times.
Still no liquids? If your Bissell has been used at least a few times, particularly if you didn't thoroughly clean the machine when finished, but after a year or so in a hard-water area like mine even if you are good about cleaning it, the water sprayers on your Bissell may have clogged with mineral deposits. This is a *fairly* easy thing to fix yourself, but please read all the way to the end and check out the GOTCHA before trying this.
Unplug the Bissell. Remove the water tank pieces from the top of the base. You'll probably reveal two red plastic pieces mounted in the Bissell's base, about .75" x .75". These spray water on your roller brushes when you press the water-and-soap trigger at the top of the Bissell's handle, and tend to clog with mineral deposits.
Only work on one sprayer at a time so you can see how it goes back together.
As you squeeze the red plastic sides of one red water sprayer, push up on the underside of the sprayer from underneath the bottom unit of the Bissell to release the sprayer from its mount in the base. Clean any lint or debris out of the mount area. Clean any gunk you can off the red water sprayer with an old toothbrush.
Now you need to remove one water sprayer from the hose. You need a pair of pliers. Use the pliers to squeeze the brass colored clip that is keeping the red water sprayed mounted to the end of the small hose there. Move the clip up the hose so it compresses the spring and is no longer on the red plastic water sprayer. (See GOTCHA about the spring, below.)
With the clip released, now you can twist and pull the red water sprayer out of the end of the hose. You'll need a little hand strength to do this. Just be careful not to break the water sprayer by using a tool. They're not particularly delicate, but breaking one would render your Bissell useless until it was replaced, so use a little care.
When you've removed a red water sprayer from the hose, put the end of the red water sprayer that was inside the hose in your mouth and seal your lips around it, and try blowing through it. If you can't blow air through it, it's clogged. Open up a paper clip and push it back-and-forth through the small hole in the hose end of the water sprayer back towards its middle. You'll probably push out a line of white mineral deposits. Clean them off the water sprayer with the old toothbrush, and try blowing through the water sprayer again. If air passes through clearly, you've fixed it. Push the water sprayer back on the end of the hose. Use the pliers to reposition the brass clip on the end of the hose over the water sprayer. Click the red water sprayer back into position in the base of the Bissell.
Now do the same for the other red water sprayer.
The GOTCHA: Once when I pulled one water sprayer off, the hose advanced up under the spring and I couldn't reattach the red water sprayer, because it couldn't reach the end of the hose. It’s best to use the brass clip or some other means (rubber band, tape, another clip) to keep the hose from crawling up inside the spring after you pull the red water sprayer off the hose. If the hose gets up under the spring anyway, despite your best efforts, fix this by removing the six screws on top of the Bissell base (this is the surface the water tank mounts on top of), and pry it up. Pull out the hose, reattach the red water sprayers on the hose, position the hose *very carefully* inside the base (there are mounts under there they need to fit into, so you don't break anything), push the red water sprayers through the mount holes and mount them, and then reattach the screws to the base.
You might want to prime the pumps again (instructions above). If the sprayers are clear, and the pumps are primed, but it still doesn't get the floor wet when it should, the problem may be more serious. You may need a pump or motor inside the unit replaced.
As you probably have learned the hard way, as I did, it's VERY important to do a lot of cleaning of the Bissell after each use, more than the manual tells you to do. Clean the bottom of the unit. Thoroughly rinse out and empty both water tank pieces. Unscrew the three clear plastic pieces, one in front, two on the sides, that surround the brushes, and rinse them thoroughly in water. Clean off the brushes and all the lint and gunk around and above the brushes. (A water spray bottle and toothbrush are helpful here.) Tip the machine and get all the water out of the hole in the base. Release the red clip springs on the red water sprayers and blow on them. Doing this will slow the failure of the Bissell. It's a great little machine for the money, but it does have a learning curve and needs more pampering than a vacuum cleaner, doesn't it??
9helpful
2answers
Bissell carpet cleaner
The water sprayers on your Bissell are probably clogged. I had this problem this morning, myself, with my machine, about 15 months old. They get clogged up with mineral deposits. This is a *fairly* easy thing to fix yourself. Read all the way to the end before trying this fix.
Unplug the Bissell. Remove the water container pieces from the top of the base. You'll probably reveal two red plastic pieces mounted in the Bissell's base, about .75" x .75". These spray water on your brushes when you press the water-and-soap trigger at the top of the Bissell's handle. These water sprayers tend to clog. See the metal spring running up the hose, behind each red water sprayer? As you squeeze the red plastic sides of one red water sprayer, use a screwdriver or other tool under the spring to wedge up the hose, to release the sprayer from its mount in the base. Stick a finger in the hole of the base of the Bissell where the sprayer was mounted and run it around the edges there including on the underside of the base to clean out any gunk you can find. Clean any gunk you can off the red water sprayer with an old toothbrush.
Now you need to remove the water sprayer from the hose. You need a pair of pliers. Use the pliers to squeeze the brass colored clip that is keeping the red water sprayed mounted to the end of the small hose there. Move the clip down the hose so it compresses the spring and is no longer on the red plastic water sprayer. Now you can twist and pull the red water sprayer out of the end of the hose. You'll need a little hand strength to do this. Just be careful not to break the water sprayer by using a tool. They're not particularly delicate, but breaking one would render your Bissell useless until it was replaced, so use a little care.
When you've removed a red water sprayer from the hose, put the outer end of the red water sprayer in your mouth and seal your lips around it, and try blowing through it. You can't blow air through it, right? It's clogged. Open up a paper clip and push it back-and-forth through the small hole in the end of the water sprayer back towards its middle. You'll probably push out a line of white mineral deposits. Clean them off the water sprayer with the old toothbrush, and try blowing through the water sprayer again. If air passes through clearly, you've fixed it. Now you have to put it back together. Push the water sprayer back on the end of the hose. Use the pliers to reposition the brass clip on the end of the hose over the water sprayer. Push the red water sprayer back into position in the base of the Bissell.
I had a problem when I fixed this on mine this morning, because when I pulled one water sprayer off, the hose advanced up under the spring and I couldn't reattach the red water sprayer, because it couldn't reach the end of the hose. So try to use the brass clip or some other means (rubber band, tape, another clip) to keep the hose from crawling up inside the spring after you pull the red water sprayer off the hose. If the hose gets up under the spring anyway, despite your best efforts, I fixed this by removing the six screws on top of the Bissell base (the surface of which the water tank mounts on top of), and then pried it up. You can pull out the hose, reattach the red water sprayers to the hoses, position the hose *very carefully* inside the base (there are mounts under there they need to fit into, so you don't break anything), push the red water sprayers through the mount holes and mount them, and then reattach the screws to the base.
There's something else you may need to do that can help get the water flowing. This one's easier. The Bissell uses pumps, which need to be primed. Sometimes an air pocket inside the machine keeps water from flowing. To prime the pumps, separate the two water tank pieces. Fill the base as usual and mount it on the Bissell without the top water tank piece. Plug the Bissell in and **turn it on**. (The Bissell must be running to do this.) Kneeling on the floor in front of the Bissell, reach up and press the soap and water release trigger at the top of the Bissell's handle and hold it in as if you wanted water to go through. On top of the water tank is a plastic grommet hole about 1 inch in diameter, through which you pour water to fill the tank. Seal that hole with the flat of your hand. You'll feel a bit of suction. Lift your hand up and down a few times. Release the trigger and repeat a few times. Now that you've cleaned out your water sprayers and primed the Bissell's internal pumps, I'm hoping water will GUSH through your Bissell once again.
As you probably have learned the hard way, as I did, it's VERY important to do a lot of cleaning of the Bissell after each use, more than the manual tells you to do. Clean the bottom of the unit. Empty all the water. Thoroughly rinse out both water container pieces. Unscrew the three clear plastic pieces, one in front, two on the sides, that surround the brushes, and rinse them thoroughly in water. Clean off the brushes and all the lint and gunk around and above the brushes. (A water spray bottle and toothbrush are helpful here.) Tip the machine and blow all the water out of the hole in the base. Release the red clip springs on the red water sprayers and blow on them. Doing this will slow the failure of the Bissell. It's a great little machine for the money, but it does have a learning curve and need more pampering than a vacuum cleaner, doesn't it??
I have a dirt devil platinum force carpet shampooer,bought it at the beginning of august this year. The sprayer seems to have stopped spraying from the main tank. The shampoo tank is letting the soap out...
you bought it in August this year
as it is 2018 and only march, it is not possible to have a problem with a machine not yet made
Besides the point , it is under warranty so take it to a service agent for a warranty repair
2answers
Usually when the hand tool works ok, then the heater inside the handle asm. is clogged. The water bypasses the heater when you use the hand tool. Other then that it could be a bad pump.
Top Karcher Vacuums Experts
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you a Karcher Vacuum Expert? Answer questions, earn points and help others
