GM realized that transmissions lasted longer and needed less fluid changes when the transmission was sealed so they stopped putting transmission dipsticks in at some point.
The 1998 Chevy Malibu does not have a transmission dipstick. Although there is a check plug located on the transaxle, near the pan, adjacent to the engine oil drain plug.
Make sure the car is in park with the engine running and pull out the transmission filler tube dipstick and wipe it off. Put it back in the same place you took it out of. Then pull it out again then look at the level position of the oil at the bottoim of the dipstick. 1 quart is equivelent to about 1/2 in
The 1998 Chevy Malibu does not have a transmission dipstick. Instead there is a check plug located on the transaxle, near the pan, adjacent to the engine oil drain plug.
Note: the vehicle must be kept level when checking the transmission fluid level.
Place an oil container under the check plug and remove it. Observe the fluid as it drips into the pan, indicating correct fluid level. The fluid level should be at the bottom of the check hole. Double check to make sure the car is level. If no fluid drips from the check hole, some fluid should be added via the red cap. But add only a little at a time until the fluid is at the bottom of the check hole.
If you can't find the stick, likely you have one of GM's "better ideas"...See if there is a fill cap on top of the trans, If it's there, there is a plug on the right side of the transmission. Remove the plug and on flat ground, fill 'till fluid comes out of the fill hole, then re-install the plug. But, the condition you have outlined sounds like the trans control is stuck in "limp mode" and may need attention (trans diagnostics) to determine if your problem is in the trans or the control itself. Especially if you see no obvious leaks fluid may not be your problem.
no dipstick on your v-6 engine, there is a plug at the top of the housing-----you can see it at the driver side of the engine down below the large air intake hose
You have what is called a closed cased transmission. You have to crawl underneathe to get to the tranny and remove the upper bolt close to the side of the case (more towards the bottom of the transmission). When you fill it, you fill it till it starts to drip out of that hole.
There is no dip stick. Its most likely not the fluid. These malibu's use the first generation GM LAN system. Check the data cord comming from the transmission near the mechanical shifting linkage. Alot of these shifting issues and errors are from a break in the wiring causing bad data to be sent/rvcd to/from the computer control module- these cars are electronically controled shifted, not mechanical.
It is usually printed on the Transmission dipstick.
Engine warm, engine running, on level ground. Check level on dipstick, shoud be somewhere between add and full. Do not add oil if it is not below the add line.
