Page 11 has self cleaning instructions.
https://www.repairclinic.com/UserManual/7915f5aca0d647b386d74abaf0ad6491/Inglis-Range-Stove-Oven-Repair-Manual-IEP315RQ1-IEP314RQ1.pdf
SOURCE: Cleaning my self-clean oven
Turn the oven to "clean" and lock the door if the oven has a manual door lock. The oven may have an automatic timer for the clean setting. If it doesn't then you'll have to turn it off yourself in three or four hours. Don't be surprised if the oven puts out a very foul smell while it's cleaning itself as that's normal for an oven that hasn't been cleaned in so long. After it's done, wait for the oven to cool and then wipe out the ash from the inside of the oven.
SOURCE: oven code E1- F5-
Have you checked the back of your oven? In the top left corner you SHOULD find a manual taped there.
SOURCE: whirlpool electric oven problem
thermal fuse to board blows, relays turn fans off, the thermal cut out on rear of oven kills element. change both fuses, install new style oversized blower.
SOURCE: whirlpool self cleaning oven 465 capacity model oven doesn't get
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
SOURCE: I have an older model
Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
you oven to go into the self clean mode(self destruct)....check out
this tip...
Self
heatman101
