25cc s/n MA1730138
SOURCE: oil/gas ratio for a modle UTO8110 homelite leaf blower
you can run 32:1 if you want to it wont hurt it but it may foul a plug since its more oil, 50:1 is the best ratio for your blower
SOURCE: need oil gas mixture for homelite HB 100 blower
50:1 with premium oil i.e. Echo, Stihl, Husqvarna.
40:1 with Homelite or generic brands
SOURCE: homelite ut o8107 blower 25cc will only idle
Hello:
Have you Removed the Muffler and Checked the Exhaust Port and Muffler for Carbin Restriction?
Remove the Muffler and Start the Unit. If the Operates Correctly, then the Spark Arrestor Screen is Clogged and the Muffler/Screen Requires Replacing.
Make Sure the Exhaust Port is Not Restricted Also.
Hope this Helps.
Good Luck
Respectfully
John
