There..what should I do next.?
SOURCE: Hi there...I have mitsubishi WD-73927 manufacture
If your TV is DLP , Then your Light engine is Bad,when color changes and little spots appear it is light engine.
SOURCE: wd 52525 red lamp light on but new lamp isn't
HI. the actual issue will be a failed ballast device. replacing this damaged power regulator will fix this issue. you can order your new ballast by clicking the link below.
Ballast(Click here to order)
SOURCE: Replaced lamp Mitsubishi WD-52531 worked for one day
Ballast Board may be Bad it is what turn Lamp on Call Encompass for parts 1-800-638-3328 or look for one on E-Bay they have good deals on Parts.Also CK Fan to Lamp it maybe defective .Call Mats for Fan 1-800-628-1118 they have lamps also.
SOURCE: Mitsubishi WD-65733 no picture, electrical buzzes in series
What it sound's like is that the lamp ballast is the problem. Buzzing sounds like when the power is first brought to the ballast it has to ramp up the voltage to get the lamp to light, then the voltage drops back down when the lamp is lit. Sounds like the lamp ballast isn't ramping up the voltage the way it should. May have to replace it. A good service shop would be able to do this for you.
Blessings,
A/V Media Guy
Testimonial: "very helpful. this was my first thought! thank you!"
