SOURCE: LG LD-2160 dishwasher
Get an aqua vac and suck out the water (with the dissolved detergent)from the salt container. Refill it with water and repeat the process couple of times. Fill the container with water and salt and it should be fine. Good luck !!
SOURCE: Bosh Dishwasher detergent drawer will not stay closed
You need a new detergent dispenser. cheers
SOURCE: Put wrong soap in the SmatDispense container...
If you run it as is you will have a kitchen full of soapy water.
Take a pot or pan. Fill it with COLD water. Our it into the DW. Fillit to the regular water level, about 1 inch below the bottom rim.
Set the DW to a pump out setting and drain it.
You will have to repeat this several times to clear the soap out.
COLD water pump out. Cold water pump out etc.
Do not use HOT water. You will get instant suds and lots of them.
SOURCE: do not know how to add dishwashing liquid to machine
Fill your clean, dry dispenser cup with detergent and close it.The water streams through the closed dispenser and comes out at the bottom of the dispenser. Make sure you have 120 deg f water coming to the dishdrawer and never put anything in that dishwasher that is to tall or comes up above the drawer when you start the dishwasher it has a lid that comes down and if it does not seal you will get an f1 code and it will require a tech.
SOURCE: Restaurant ran out of 'commercial' powdered
do not use nocommercial dish washer powder, it may ruin ur recirculating sump pump, alwasy us manufacture recomendation, or you will void the warranty
