SOURCE: HOTPOINT AQUARIUS WF440 BEARING REMOVAL/REPLACEMENT
Are you talking about the main tub bearing?If so I dont recommend replaceing this bearing,because the problem will only keep repeating itself.
SOURCE: hotpoint aquarius wf340
First remove the filter (if you can do this easily) - place a roasting pan under it to catch the water.
If you cannot get to any filter, remove the rear pipe from the waste pipe, and check it is not obstructed.
If it looks good enough, try a hot wash with 1 cup of soda crystals. This should clear any accumulation of grease in the pipes.
If still no good, you may have to open up the machine to clear any internal filter before the pump, and check pump vanes are still intact.
SOURCE: Hotpoint aquarius 1100 bangs while spinning
Several possible reasons for this. M/C not level, causing it to move about.
Overloading of m/c.
Loose concrete balance weight, there is one at top and one at bottom.
Suspension spring broken or unhooked.
Suspension leg loose or broken.
Main drum bearings worn, to check this, turn drum by hand and if it feels noisy or rough , then bearings have gone (expensive repair).
There are other possible causes, but these are the main reasons.
Plz rate my solution.
Thanks.
SOURCE: Hotpoint DW440 flashiing lights
I have just seen the same problem on a neighbours WD440G. I have
tracked down the problem to the main circuit board at the back, bottom
of the machine. Transistor/FET Q9 has exploded. There was water at the
bottom of the machine and the wiring in the vicinity of the nearby
connector was wet.
This neighbour is in no financial position to be able to buy a new
board, or get an official Hotpoint engineer to confirm what we already
know. Anyone know where I can get a schematic diagram for the board?
