SOURCE: my 308 winchester 99e lever action jamed, had to
found someone on internet that sent me the plan for free. by searching you can save money.
SOURCE: I have a winchester model 88 lever action rifle
you have your self a nice rifle there.i like the .308
OK this is what ya do.open the action and you will see the screws that hold the back part of the receiver in remove them.on the upper side the older model had a screw on the receiver end take that out.up on the for are there is one more on the bottom side remove that.now it will come out in one unit leave the leaver down and grab the front of the stock and pick up on the barrel as your sliding it forward.
SOURCE: 30-30 winchester lever action model number 94ae
Take it to a reputable gunsmith or Auction house, they will be able to advise you.
SOURCE: I have a pre 1964
TRY REMOVING THE MAGAZINE PLUG SCREW (WATCH OUT FOR THE SPRING!) TRY HOLDING THE MAGAZINE PLUG SCREW WITH YOUR HAND AS YOU REMOVE IT SO THE SPRING DOESN'T COME FLYING OUT. REMOVE THE SPRING AND TRY CLOSING THE LEVER. IF IT NOW CLOSES THAT WAS YOUR PROBLEM. REASSEMBLE THE SPRING AND SCREW AND YOUR PROBLEM IS SOLVED. IT THIS DOESN'T WORK LET ME KNOW AND MAYBE I CAN COME UP WITH SOMETHING ELSE.
SOURCE: what height mount/rings do I need to mount this
low mount rings should clear with about 4mm clearance.
measure from bottom of mount to bottom of scope, that is the clearance you need in the mount from the bottom of the ring. Drop by a gunshop if you are not sure, take rifle with you, then you can trial fit till you find the lowest that will clear. The lower the scope the, the closer to the center bore, the longer the flat spot/intersection plane.
