SOURCE: Ironman Triathlon Sleek Ladies Watch Band Rubber Strap Discolors
Unfortunately there is no way to get rid of that discolouring.This is due to sunrays+swetting+chemical composite of strap material. Would be too long to explain how it works, so, here is the link where you can order the new strap:
http://www.timex.com/gp/node/n/256542011/ref=sc_bb_c_11_251377011_15/190-2521384-6105829?ie=UTF8&node=256542011&no=251377011&timexBrand=core&me=A1S5XB33AHYRMX&clicked=center-1115
Rate me, please.
SOURCE: i have a sector 600 series with a black rubber
Here you will find Sector contact details:
http://www.sectornolimits.eu/#/eng/contact
And here is the link where you can find nearest Sector:
http://www.watchservicecenter.it/
You have to contact them and ask for the strap/bracelet you are after.
Rate me, please.
SOURCE: the strap is broken on casio watch
I had exactly the same problem with exactly the same model watch, and it happened to me twice. The AQ-160 is the important part of the model number as far as replacement parts are concerned. The first time, I took it to the shop where I bought the watch, and they replaced the band, but it cost me $50. The second time, I looked up the Web for the master agent for Casio in Australia, and they said I could buy the end piece, not the whole band, for $6. I found I could replace it quite easily myself by using a drawing pin to remove the spring pin that holds it together. A bit fiddly to reassemble but not too bad. In fact, I didn't wait for the new part to arrive, just used the unbroken end of the old band. So now I have a repaired band plus the old band and a new end piece, in case it ever happens again.
I really like this watch, but it is a pity the bands are so weak.
SOURCE: hi Got a guess watch with rubber strap which has
you will prob need the same strap as most are integral to watch if i remember Seiko make guess watches try there website first or try guess watches they will ask you for model and sometimes serial numbers and they will send it in the post to you or maybe ebay but you take a risk ..then pop round to your local repairer and ask them to fit it..
Please dont forget to vote this answer was helpful.
Many thanks
