SOURCE: Disney Princess CD Player will not play music
try cleaning the laser with a q-tip if the laser is dirty from finger prints or dust it won't be able to read the disc therefore won't play. Clean laser and if that doesn't work then the child may have damaged the player in a fashion that would be better to get him/her a new one.
SOURCE: Disney princess dvd player will not play any dvd!
We had the same issue. Try clicking <play>1234<play> and it should unlockk the dvd in the machine. Seems to work on my daughters. It's a parental control of come sort. HTH.
SOURCE: i need assembly instructions for disney princess
Use the hardware that comes with
the Disney Princess canopy package to install the main canopy hook in
your ceiling. Center the steel ceiling hook above the center of the twin
bed and screw it into the ceiling by hand or with pliers. 2 Follow the included instructions
and insert the four poles into the sleeves of the canopy. The two
longer poles will run lengthwise above the bed, while the two shorter
pieces will run widthwise above the bed. 3 Attach the canopy to the ceiling
hook by slipping the plastic ring of the canopy onto the hook. The four
polyester sides of the canopy should now hang over the twin bed. 4 Use the customer support form through the Exxel Outdoors website if you have questions regarding your Disney Princess canopy.
So I have 2 daughters myself and they too are crazy about
everything princess themed. I know of a
great youtube video that you may find helpful.
http://www.youtube.com/watch?v=pHwxsiw4p_w
Also, I will send a few links to places that sell these beds
& bedding.
http://www.walmart.com/ip/Disney-Princess-Toddler-Bed/13325927
http://www.nextag.com/princess-toddler-bed/compare-html
http://www.walmart.com/ip/Disney-Princess-4-Piece-Toddler-Bedding-Set/4200986
