SOURCE: 2004 explorer dash gauges acting crazy
check and make sure all the fuses are in good but it sounds like a bad ground wire
SOURCE: will start but rpm gauge jumps up and down then it dies
The problem you describe has NUMEROUS causes. Most common of these is a COIL is going bad. The RPM gauge gets its signal from the ignition coil/crank sensor circuit (could be either one OR could be the wiring between the engine control module (ECM) and the engine components. Does the Check Engine light come ON when this happens? Whenever the "Check Engine" light comes on, there is always a DTC (Diagnostic Trouble Code) stored in the ECM (Engine Control Module). You'll need an OBDII (On-Board-Diagnostics) scanner to retrieve any codes recorded/set in ECM. Once you do this and let us know what, if any codes are set, then we can go from there.
SOURCE: My remote won't start my 2005 Buick LaCross. I
Both my remotes no longer work. I will be ordering new ones off Ebay and having my dealer program them. New ones from Buick are very pricey.
SOURCE: what is procedure for reprogramming a remote
only a dealer or someone with a tech 2 and a cadi module
SOURCE: 2006 buick lacrosse how to replace headlight low
The bright light fitting is the same as the dim so take it apart fist to see how the cover screws off/on and the light comes out. Both the cover and the bulb are removed by a standard twist to the counterclockwise and replaced by a twist to the clockwise. Now to the dim light. You have to release the entire light assembly before you can remove the screw-on cover to reach the light. On the rear edge of the light unit closest to the engine is a white locking tab. Pull that tab up just to the point where it releases…pull too far and it locks again. Next, locate the other locking bracket which is a metal bracket in the center-rear of the light assembly. This bracket is held down by a screw. Remove the screw with a 10mm wrench. Lift the bracket just like you did the white bracket. You should now be able to pull (or pry) the entire light unit forward a little. Depending on the size of your hands this might be enough. If not, then you need to release the plastic bumper assembly to give you a little more space. This is done by removing two expansion locking pins, one that holds the little plastic strip down between the bright and dim lights and one that is located inside a rubber bumper on the engine side of the light unit. To remove these locking pins, pull or pry up the little tab in the center of the pin just like you were pulling a nail by the head. That should give you a little more space.
