You have a bad thermal fuse , located on the blower box . A small white plastic piece with 2 wires going to it . May have to remove the front panel to access it . Usually caused by kinked vent hose or clogged vent .
HI, the timer is defective. the heating process can be affected if the timer isn't functioning correctly. replace this failed timer asap. this will fix the issue.
I have a kenmore gas dyer, it will start to dry then go out and just run. you can shunt it dwn resit the timer the time it needs start it and it will lite for a cycle then go out, short burn, then out. is it a senor???? JW
