SOURCE: samsung ht ds1000 audio problem
I had the same issue 6 months after I purchased the unit. Worked with tech support several times. Finally they sent new woofer and that fixed it.
SOURCE: Can't download Audio with video from Handy cam (Sony DCR SR 67)
http://esupport.sony.com/US/perl/model-home.pl?mdl=DCRSR67&LOC=3
There is troubleshooting for the Sony DCR SR 67 at the web link above.
SOURCE: connected the L/R audio and
Here is a link to the user's manual for your Onkyo DS777 in case you did not have a copy already:
http://www.intl.onkyo.com/downloads/manuals/pdf/tx-ds777_tx-ds676_manual_e.pdf
To view the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents. You can download this free at WWW.ADOBE.COM if necessary. Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, and then just follow the onscreen instructions to install it.
See page 8 of the ONLINE USER'S MANUAL for detailed instructions and illustrations on how to connect VIDEO equipment to your unit.
Make sure your VIDEO / S-VIDEO OSD Selctor Switch on the back of the Onkyo (Item 4 on the diagram) is set to the correct output mode depending on which kind of cable you are running to the TV/Monitor. Select VIDEO if you are using a standard RCA cable, or select S-VIDEO if you are using an S-VIDEO cable.
If you are using an RCA cable for the INPUT to your Onkyo, then you must use RCA cables as the OUTPUT to the TV/Monitor.
If you are using an S-Video cable for the input, then you must use an S-VIDEO cable for the output as well. You cannot mix the two.
Also make sure that the VIDEO 3 INPUT MODE is selected on the MULTI CHANNEL INPUT button on front of the unit (see page 26 of the manual, item 1 in the diagram).
Please comment back here to this page if you have any questions, have difficulty accessing the link, or just require further general assistance and I will respond as soon as I see it.
Thank you very much and good luck.
Joe.
SOURCE: my ak59-00123A samsung remote will not work for the BluRay HT-D4500/ZA
Blu-Ray players cannot be set up with other remote controls other than its original one.
The. Remote control model number is
BP59-00016
