SOURCE: 96 cavalier 2.4 starts runs great -chokes
Check the crankshaft position sensor. If the plug is loose or the sensor itself is bad it will cause similar problems
SOURCE: bike contuines to back fire acts like not getting fuel thru line
spark plugs are bad change them if that dosent work adjust ur timing adjuster!!
SOURCE: Stale Fuel in gas tank
go to any auto parts store and get one of the products they have to remove the gum in the carburator and line. Some of the products are simply poured into the gas tank along with some fresh gas. good luck.
SOURCE: Lawn mower engine runs rough and puts out white smoke
Pull the carburetor and clean it for staters.Be sure to change oil any little bit of moisture in the crankcase will let it smoke white by seeping by the valves and piston rings.Also put a little small amount of dry gas in the gas tank to rid all of the water that may have been left in the tank. I some of this will help you.
SOURCE: I have a 1 yr. ferris mower 2000z 61'' It dies when apply brake.
IT COULD BE THE SEAT SWICH OR THE BRAKE SWICH
Testimonial: "checked all switches w/Ohm meter all sw's are working, could the delay box be bad? Id like to by pass all of these switches. "
