Question about Video Cameras
I bought a used GZ-MC100, bought an SD card separately, but it keeps formatting, automatically shutting down and then tell me again a formatting is required. What should I do?
    Dedicated:
    Visited the website for 20 consecutive days.
  • Video Cameras Expert
  • 434 Answers
Replace the card with a low capacity
Posted on Jun 17, 2018
SOURCE:
SOURCE: sd card format
Acording to motorola, The SLVR L7 is limited to a 1G micro SD card. Anything over this will not be usable in this phone.
Posted on Dec 29, 2008
  • 34 Answers
SOURCE: Is there compatiblity between the SDHC card and JVC GZ-MC100?
Check the user manual and the JVC website for a new firmware.
"Can I use Multimedia Card (MMCA), xD, Micro SD, MiniSD or Memory Stick in EVERIO?"
Posted on Jun 06, 2009
Rexdreamer
  • 76 Answers
SOURCE: I have a JVC 20
There should not be anything to install when inserting an SD card, all you do is put the card in the card slot. If you tell it to format you have to go into the menu first and tell the camera which you are referring to the card or the harddrive. If you didnt change the setting to SD card when you did give it the format command than that is why your data was lost. If you are having an SD card error make sure that the little slide switch on the card is set as not to protect the card that will give the error sometimes. I hope this helps
Posted on Sep 16, 2010
paul2010
  • 160 Answers
SOURCE: the sd drive keeps telling
unfortunately I suffered the same prob, I found a small crack at the base, but you could also try to slide the card protect switch back and forth a few times, this can some times work
cheers
paul
Posted on Nov 15, 2010
  • 1481 Answers
SOURCE: 8GB SD card says: MEMORY
i guess you are using it thru a USB, try a differnt USB port if you have more than one USB port on your PC....else
try it on a different PC
or
a longer solution is to get a low level format software like "killdisk".....this is also a DOS based application....install it and use the in Win or thru a boot diks DOS application
revert back
Posted on Jan 06, 2011
I have a brand new JVC GZ-MS100 and a brand new card
The 32GB SDHC card may be a "class 4" card, not a "Class 6".
Look at the card and find the circle with a number in it.
Class 6 is the highest speed available. Class 4 is much slower and can't keep up with video.
Not all 32GB sdhc cards work with all camcorders.
Try formatting the card twice in the JVC.
Sep 22, 2009 | JVC Everio GZ-MC100 Memory Card Camcorder
Tip
MOD Files on Mac OS, How to Play Camcorder MOD Files on Mac
Similar to TOD, MOD is a kind of recording format being used in digital tapeless camcorder like JVC, Panasonic, Canon. MOD video format is comparable to XDCAM EX, HDV and AVCHD.
MOD is used exclusively for standard definition video files, while TOD is used for high definition files. Both MOD and TOD are file-based formats that are stored on a random-access media. Directory structure and naming convention are identical except for extensions of media files. Standard definition video is stored in MPEG program stream container files with MOD extension; in most other systems these files have extension MPG or MPEG.
The following list is about JVC, Panasonic, and Canon MOD camcorders.
JVC MOD camcorders
* 2004: GZ-MC100 (SD), GZ-MC200 (SD)
* 2005: GZ-MG30 (HDD), GZ-MG70 (HDD)
* 2006: GZ-MG37 (HDD), GZ-MG77 (HDD), GZ-MG505 (HDD, SD/SDHC card)
* 2007: GZ-MG130 (HDD), GZ-MG155 (HDD), GZ-MG255 (HDD), GZ-MG555 (HDD, SD/SDHC card)
* 2008: GZ-MS100U (SD/SDHC card)
* 2008: GZ-MG7230 (30 GB HDD, MicroSD)
* 2009: GZ-MG630 (60 GB HDD, MicroSD), GZ-MG670 (80 GB HDD, MicroSD), GZ-MG680 (120 GB HDD, MicroSD)
Panasonic MOD camcorders
* 2003: SV-AV100 (SD card)
* 2005: SDR-S100 (SD card)
* 2006: SDR-S150 (SD/SDHC card)
* 2007: SDR-S10 (SD/SDHC card), SDR-H18 (HDD, SD card), SDR-H200 (HDD, SD/SDHC card)
* 2008: SDR-H20 (HDD, SD/SDHC card), SDR-H60 (HDD, SD/SDHC card)
* 2008: SDR-S7 (SD/SDHC card)
* 2008: SDR-SW20 (SD/SDHC card)
* 2009: SDR-SW21 (SD/SDHC card)
* 2009: SDR-S26 (SD/SDHC card)
Canon MOD Camcorders
* 2008: FS100 (SDHC), FS10 (SDHC), FS11 (SDHC)
* 2009: FS200 (SDHC), FS21 (SDHC), FS22 (SDHC)
For Mac users, when they want to watch MOD files shot by JVC, Panasonic, Canon camcorder with iPad, iPhones, iPods, in Quicktime, in iMovie, in iTunes, or on PCs, etc. They may be annoyed that how to upload MOD files to Mac and play MOD video on Mac OS.
Now, there are tutorial and guide for you below will help you solve these problems.
1. Connect your JVC, Panansonic, or Canon camcorder to your Macs or PCs with cable USB or Wifi.
2. Turn on your camera and select the mode of camcorder like PC mode. iMovie on Mac will open automatically the Import Window.
3. You can review your video or select "Import All"and select your JVC, Panasonic, or Canon camcorder on the computer screen and click "OK."
4. All camcorder MOD videos will have the file extension "MOD" Once the backup is complete, then close the program.
After uploading your camcorder MOD files to your PC or Mac, you can use
a MOD Video Converter for Mac to convert MOD files to Mac firstly, and then you can play JVC, Panasonic, or Canon MOD files on Mac. More information about how to convert MOD files on Mac and edit MOD files on MacOS you can click here.
on Sep 13, 2010 | Computers & Internet
Tip
How to Upload/Put and Play JVC, Panasonic, Canon Camcorder MOD Files on Mac
JVC MOD camcorders
After uploading your camcorder MOD files to your PC or Mac, you can use a MOD Video Converter for Mac to convert MOD files to Mac firstly, and then you can play JVC, Panasonic, or Canon MOD files on Mac. More information about how to convert MOD files on Mac and edit MOD files on MacOS you can click here.
on Aug 12, 2010 | Computers & Internet
"please insert memory card in GZ-MG130U CAMACORDER
Hi there.
The hard drive will be full so you will need to transfer all your videos to your PC then format the hard drive in the camera's menu, make sure the SD card is removed before you format it.
Good luck and thanks for using FixYa!!
Mar 16, 2009 | JVC GZ-MG130U Camcorder
Download manual for JVC Digital media camera GZ-MC100
If you are looking for User Manual of GZ-MC100, you can download it from JVC Support.
Nov 29, 2008 | JVC Everio GZ-MC100 Memory Card Camcorder
Error with CF card
did you delete all card files on your pc?
if so, camera will not function properly. Try formating the cf card on your computer and format it again inside JVC camera,
try inserting a normal cf card(should work) in order to find if you have a faulty cf card
hope it helps
marco
Nov 05, 2008 | JVC Everio GZ-MC100 Memory Card Camcorder
Download cd's for jvc gz-mc100
this camera doesn't come with software to transfer videos. Just plug your camera (or insert the cf card, on a card reader) and copy your videos to your pc. you can use the image import feature on windows to do the job (but don't delete the videos with your pc. If you do the camera will state a error)
hope it helps
marco
Sep 26, 2008 | JVC Everio GZ-MC100 Memory Card Camcorder
Jvc/everio GZ-MG130U DRIVER
try here on this link it might be helpful. download the driver that the same with your camcorder. it might work. hope that helps!
https://www.jvc.ca/en/consumer/service/s_downloads/default.asp
just try to copy and paste it to your url address. dont click it just copy it. ive tried it anyway and it still working. hope that helps!
CHARCOIS
Aug 26, 2008 | JVC Everio GZ-MC100 Memory Card Camcorder
Formatting?
try to format the cf card on a pc (use a card reader)
Hope it helps
marco
Nov 23, 2007 | JVC Everio GZ-MC100 Memory Card Camcorder
Video Cameras Logo
255 people viewed this question
Top Video Cameras Experts
Marvin
Marvin
Are you a Video Camera Expert? Answer questions, earn points and help others
