SOURCE: My Konika Minolta Bizhub 361
Replace the Fixing Sensor assembly (p/n 50GA -544 0).
Fusing main sensor low temperature abnormality. While in the idle or in the low power mode, the fusing heater lamp /1 (L2) turns on for more than 12 seconds in succession.
SOURCE: my konica minolta bizhub 361 has an error code
In my experience you have to change the developer and the machine will be ok.Also there is a chance that you have to clean the two toner sensor that are located in the end of the toner bottle,sometimes there is the problem.please let me know.
this is an abs code. it means your rear abs sensor is bad. it is right in the middle of the rear axel on the top. it has wires going to it and looks like a little box
