Need to notify netflix
Hello, Annette -
See the information on how to cancel Netflix here:
https://help.netflix.com/en/node/407
First, you will need to sign into your Netflix account. On your Netflix Account page, you should see the link to Cancel Membership. Click or tap on that link. Follow the on-screen instructions.
How did I find the information? I used my favorite search engine, Google, and the following search phrase:
cancel Netflix
How hard is that? :)
Best wishes.
SOURCE: netflix states that my problem with not seeing
Step 1:Connect Modem - Router - Computer (Wired)
Step 2:Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3:On the Left click firewall
Step 4:Leave the Password blank and click submit
Step 5:Disable it and click apply changes
Step 6:Scan and connect in the Xbox/PS3/Wii
Step 7: Get the IP Address of the Xbox/PS3/Wii
Step 8:Open Router Setup in the Computer
Step 9:On the left under Firewall Click DMZ
Step 10:Enable the IP Address of the Xbox/PS3/Wii in it
Step 11:Click Apply Changes
Step 13:On the left Under Utilities click System settings
Step 14:Scroll down to the bottom
Step 15:Enable UPnP
Step 16:Click apply changes
Step 17:Test the connection ,Check the NAT
If working then let me know
Goto : my blog for more information about belkin routers (Page is still under construction )
- Tom Riddle :-)
SOURCE: we're unable to connect you
Where unable to connect you to netflix.please try again or visit www.netflix.com/ps3 help for guidance
SOURCE: downloading netflix
How to get Netflix to work on a Wii
1.) turn on your wii
2.) press "A" (or any button to get to the wii menu)
3.) on the Wii menu, go to the bottom-left of the screen
4.) click "A" on the word "Wii" (when you highlight it, it should say "Wii Options")
5.) then click on "Wii Settings"
6.) on the contoller, hit the "+" button then click on "internet"
7.) then click on "connection settings"
8.) click on any connection setting (i just use the the one that says "connection 1")
9.) if you want to connect through a wireless connection, click on wireless connection (this will search for WiFi around you.)
10.) then go to "search for an Access Point"
it should find some access points, if it doesn't, then you'll need to
buy a Nintendo WiFi thing (i'm sorry, i forgot the correct name for it)
11.) click "OK"
12.) click on an access point with a lock that's unlocked, or click on
one with a yellow lock and put a password. if you see a red lock, you
cannot connect to that access point.
13.) it will ask you if you want to save the settings. click "OK"
14.) then click "OK" again, to do a connection test (this could take about 30 seconds)
15.) UPDATE THE WII
16.) after that go back to the Wii menu by clicking "Back" until you reach the Wii menu
17.) then click on the wii shop channel.
18.) then click on start shopping
19.) then click on channels
20.) then click on netflix
21.) wait for it to download
22.) then go back to the wii menu
23.) then load up the netflix channel
24.) they're going to give you a password, go on a computer and (if you
have a netflix account) go to www.netflix.com/activate or
http://www.netflix.com/NRD/Wii?mkwid=s0BEmMX1Q&mqso=80025460
25.) then loggin and type in the code from the wii into your accound
...Now you can watch Tv or movies on your Nintendo Wii
SOURCE: Canceling
Goto https://www.netflix.com/YourAccount and login if necessary. Right under the 'Your Account' in bold text in the upper left corner, you should see "MEMBERSHIP & BILLING" with a cancel button underneath. Click it and it will let you cancel your netflix account entirely.
