HP Photosmart M447 Digital Camera Logo
Posted on Aug 01, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do you unlock your memory cards for your digital camera?
My 2gb memory card for my digital camera is like locked. I try to take or delete pictures and it says Card is Locked. What do i do to get it unlocked?
Anonymous
Level 2:
  • Expert 63 Answers
  • Posted on Aug 01, 2009
Anonymous
Expert
Level 2:
Answers
63
Questions
0
Helped
13392
Points
211
Take a look at the card it should have a switch on the side just slide it and it should be unlocked
1 Related Answer
Anonymous
  • 64 Answers
  • Posted on Jan 06, 2008
SOURCE: locked memory card
There is a tiny switch located on the side of the memory card, might even say lock on it or beside it. Just flick the switch opposite of the way it is now and it should work fine after that. There might even be a small arrow showing which way to switch it. The reason for the lock button is "just" for this, so you don't accidentally erase some wanted pictures or someone else.
2answers
Kodak easy share c183 memory card protected how to reset
Camera LCD: "Memory card is protected (Reset ... - Kodak
support.en.kodak.com/.../camera-lcd%3A-memory-card-is-protect...
KodakAug 25, 2010 - The camera screen displays "Memory card is protected (Reset switch on card). ... The memory card is locked so that data (pictures, videos, or files) ... The disk is write protected." when writing to or formatting an SD card. Share.
[PDF]KODAK EASYSHARE C183 Digital Camera
resources.kodak.com/support/pdf/en/manuals/.../C183_xUG_GLB_en.pd...
Kodak, EasyShare, Max, Perfect Touch, and Pulse are trademarks of Eastman Kodak. Company. ..... Access to more manual settings than Smart Capture mode. ..... NOTE: To delete protected pictures/videos, remove protection before deleting.
Memory card is locked and cannot delete pictures
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
EVERY PICTURE I CLICK ON SAYS LOCKED IN MY SANYO 14.0 CAMERA
if your problem is seems in ur memmory card..you can try after unlock ur car...there is a small key in the memmory card's side for lock and unlock...
When i insert my fujifilm 2gb memory card into model jv100 all i can do is look through my pictures i cannot delete or use anything else ,and a icon comes up in the centre of the screen when i look at my...
A few things but the first that comes to mind is that there is a little slid lock on the upper left side of the memory card. This lock needs to be pushed forward towards the gold contacts to unlock the card. Another problem could be tat the 2gig card is full of pictures and needs to be downloaded to your computer. Once this is done the card will need to be formatted to clean the old pictures off and make the card ready for new pictures. I suspect when you take this card out (2gig) the camera defaults to internal memory and yes everything will work as it should until the internal memory is full of pictures as well
1helpful
I have tried to delete pictures on the memory care
When you pull your card out of your camera, look at it and you should see a little switch that can unlock the card. It is just like the little switch on a 3.5" floppy disk, if you can remember what those are.
Canon SD1200 IS won't save pictures to the memory card.
This Canon uses an SD memory card (previous Canon used CF cards).
The SD memory card has a "slide switch" that locks the card.
Look at the SD memory card and move the switch back and forth, then switch it all the way to the UNLOCK position. Put back in the camera and format the card, then use it.
Since this is a 10Megapixel camera, use at least a 2GB SD memory card. A 2GB SD card will hold 700 pictures, or so, in the best setting.
Hope this helps!
CARD LOCKED
take out the memory card and move the switch located somewhere on the memory card usually on the side to the unlocked position. Then the memory card isn't locked this is so you don't accidentally delete important things
Thanks and enjoy,
Lee
Canon A560 will not erase pictures
Two possible solutions.
1. Apple users have reported that the switch on the memory cards performs the file lock function in either extreme positions Lock/Unlock. In some cases they have achieved success in centering the Lock/Unlock switch allowing access to the read/write operation of the memory card
2. Connect to PC
Access drive via windows explorer
Right click on drive (MEMORY CARD)
Select properties
Confirm that RO (Read Only) is not selected.
Selected RO
Try reading card
Repeat properties un-select RO
Try deleting files
If not successful card is likely defective
Hope this helps?
1helpful
Card Locked ! Error
Remove SD card, then whilst card is removed, delete all pictures that may still be stored in cameras 'internal' memory (usually just a few) then replace SD card. Should be unlocked now?.
4helpful
Memory Card Locked.... how do I un-lock it?
Your memory card has a small white "switch" on the side. Move the switch and your card will unlock. It is a saftey so you don't erase anything accidentaly.
Top HP Cameras Experts
 Mikey
Mikey
ADMIN Eric
ADMIN Eric
Are you a HP Camera Expert? Answer questions, earn points and help others
