I will assume it's a spinning reel, and then you may have several methods. You can tie a slipping knot on the line, open the pickup, slip your knot on the reel spool, tighten it, and then reel in. A more efficient way may be to install your reel on the rod, first pass your line through the first guide, and then do the same things. Tie a knot on the spool, with the pickup open, and reel in. Now when you reel in, I can suggest you to do this in a bucket of freshwater, as it will tighten your line with no efforts, and the line spool will not jump all over the place.
Click Here For Fishing Tips & Tricks
SOURCE: threading reel to reel
Depending on which brand of recorder you have, most do have a general threading scheme. As you are facing the unit, the supply (full) reel would be on the your left and the take-up (empty) would be to the right. Position the supply reel so that the leader end of the tape will be on the outside. Pull the tape end around the shut off sensor lever so that it moves freely. Now pull the tape leader between the rubber pinch roller and capstan (in the case the unit has dual capstans). If it has a single roller on the right side, pull the tape between the heads and then between the roller/capstan. If unit has dual shut off sensor levers, pull tape around this sensor as you did the first, making sure it moves freely. Then thread the tape leader into the take-up reel slot. Press play. Both reels should turn counter clockwise.
SOURCE: penn fishing reels
For a Penn GTO 220, pls check this page an exploded view of the GTO220 that details parts and their placement. It is a PDF file and would need Abobe Acrobat Reader to view and print.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
SOURCE: How to reel in a fish
To reel out push on Z on the nunchuk and continue to rotate nunchuk or push on B and Z
SOURCE: I do not know how to thread line through reel
put spool of string on a pencil and have someone hold it, now snake the string through the eyes of the pole and attach it to the reel, on the small shaft in the middle, then just reel your pole in untill you reach YOUR limit of string..
SOURCE: Cannot open Shakespeare Synergy Steele 2001s fishing reel
alright man......i had the same problem. it just takes a little bit of elbow grease, bot it does twist open, it's just harder than hell to get it to twist off. I took a towel and laid it over the reel, and lightly tapped on it with a hammer to loosen it up a bit.
