YouTube comes on, but doesn't personalize icon with my first name
Hi, I have a suggestion for you just visit on this link and find apple customer service phone number and ask your problem about your Apple device may be this link is helpful for you please visit on this link https://bit.ly/2P5lXNm
SOURCE: ipad can not connect to youtube
hello Sir
when You Connect To youtube app it says " cannot connect to youtube "
here are the steps to fix this
go on itunes on computer with Ipad plugged in
on the computer itunes , there should be a little that says apps
click the apps then try youtube
It works ==)
SOURCE: taken delivery of 40" samsung
Make sure you have it set to wireless off in the menu or it will not recognise the ethernet port on the back even if it is flashing. Most tvs with browsers come with the wirless function set to on. Also if it has search for internet signal you could try this to get it to rec. as well.
SOURCE: i am trying to connect
The BT205 only has a HDMI Out so you need to connect both your BT205 and Apple TV to your TV either directly or through your splitter (depending how many HDMI Inputs your TV has).
You then need to connect either the Digital or Analogue Audio Port from your Apple TV to your BT205 and select the Audio Output from your BT205 as detailed on Page 27 of the manualat the link below.
http://tda.panasonic-europe-service.com/docs/2z4e3b157ez3z2a0dbz656ez706466z21z3703f025f4fa80ffdb9e5a7957895ca96b778f45/tsn2/data/ALL/SCBT205/OI/812908/rqt9445-b.pdf
This will give you the picture from your Apple TV to your TV via the HDMI and the Apple TV sound to your BT205 via the Audio Port.
SOURCE: Could not see the person on the other side when using skype
uninstall skype and install it again.it will help
SOURCE: How do I connect my ps3 to the Samsung smart tv
For best performance I recommend you connect a HDMI cable from the PS3 to the HDMI input on your TV.
To display the PS3 you need to select the HDMI input on your TV.
