Where can I find a Manual for Venstar S404 Cycling Speaker?
    Habit-Forming:
  • 109 Answers
Sorry i couldnt find it .
However i found a review that should cover all speaker functions . Below is the link
https://youtu.be/urb8Ai6yOP0
Posted on Jun 03, 2018
  • Anonymous May 26, 2019
    doesnt show you actual way of pairing instructions
SOURCE:
Venstar t1800 displaying OF instead of the cooling set point in manual and automatic modes
The "OF" usually stands for "Other Fault" You need your user manual to troubleshoot how to get the specific fault code to determine what's wrong.
Sep 18, 2017 | The Office Equipment & Supplies
How do I program the Venstar T1010 digital thermostat. I did not receive a manual with it.
Venstar has the documentation for the T1010 thermostat on their Small series (Residential) support page: http://venstar.com/thermostats/small-series/literature/ . The direct link to the user manual is currently http://files.venstar.com/thermostats/small-series/documents/T1010ManualRev1.pdf .
To set the time, press Mode and Fan at the same time and hold for 2 seconds. This will put the unit into set up mode. Use the up/down arrows to change the currently flashing item. Press and hold Fan while pressing either the Up or Down arrows to quickly change the item. Press Mode to move between time sections. After you advance to the section for heating/cooling mode, you can press Mode to change between the available options. Press and hold Mode and Fan to exit this setup area.
Press and hold Mode and the Up arrow for 2 seconds to program the timed heating or cooling intervals and temperatures. Press Mode to move between time period, desired temperature for heating or cooling for that time interval and the next time period. Use the Up/Down arrows to change each section. When finished, press and hold Mode and the Up arrow to exit.
I hope this helps.
Aug 12, 2017 | Heating & Cooling
How to replace battery on Totaline P474-1100RF
Complete Manual for T1100RF and P474-1100RF Made by Venstar
See picture, and yes, Lithium batteries need to be used. Alkaline may work in a pinch until you can get some Lithium.
Mar 08, 2013 | Heating & Cooling
HOW TO UNLOCK VENSTAR T 2800
how do I get the lock off the keypad
Mar 01, 2013 | Venstar T2800 Slimline Platinum...
I have a minolta dimage s404 I need the size of the usb cable for downloading from the camera to the pc
Hi, i don't quite understand when you mention size, but the actual size for Minolta Dimage S404 is USB 1.1, it is capable of supporting a transfer rate of up to 480 Mbps and is backwards compatible.
if you want to buy a USB cable online then you can try this specification.
May 10, 2011 | Cameras
Minolta dimage s404
hey i know this has nothing to do with the topic, but can you help me with something? i accidently turned my toastmaster toaster oven on/off dial onto stay on. do you know how to get it off beacuse now it just wunt turn off. thanks
Jan 09, 2007 | Minolta Opteka .5x Hi-Def Wide Angle Lens...
Crazy cycling noise
a quick test, change the speaker wires between the speakers, if the sound goes over to the other speaker the problem is in the amp. But if the problem stays with the same speaker tower the problem will be in one of the speakers in the tower. since you said you get no sub sound I suspect ithe problem is not the amp, but the sub speaker itself
Oct 26, 2006 | Polk Audio RT1000I Speaker
562 people viewed this question
 Grubhead
Grubhead
Steve Allison
Steve Allison
