Mi laptoptop es windows 10
SOURCE: Conectar JVC GR-DVM5 al ordenador con el sistema operativo Vista
necesito drivers para bajar videos desde mi camara jvc gr-dvm5 al computador que tiene windows vista home.alguien me puede ayudar con alguna informacion o sitio donde los puedo encontrar??
SOURCE: Que puedo hacer para actulizar windows xp, por el xp pack 2?
ve a este sitio y bajalo
despues, abrelo y se installara solo.
SOURCE: estrella de validacion
Translation from Espaniol: when booting windows I get a star on the toolbar that says my version of windows is not valid and puts the ondo of the screen in black as I can make it out, that translation of what he said. My Advice: You should get a validated or at least a non-fake version of windows. Translation: Usted debe obtener una validación o, al menos, no falsas las versiones de Windows.
SOURCE: NO PUEDO HACER QUE FUNCIONES IR-323O
Double click on the site for I-rocks Camera driver, go down
to
Multimedia and download the driver.
http://www.i-rocks.com/Download.aspx
After you download the driver, then do this:
Disconnect
the Camera from the USB port and reinstall the CD or Downloaded software
program. When the program asks you to connect the camera to the
USB port, do so and it should work.
Then to use it on the Web, do this.
Web Camera’s have to be
setup on the program they are to be used with. Just installing the camera
on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for
the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/
) set it up as follows:
The camera and audio should function properly. Your
friends and Family will now be able to see and her to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger
(http://www.soft32.com/download_30.html
Hope
this helps. Bud
SOURCE: mi problema es con una laptop Toshiba Satelite
Sabes que es encrypcion WEP o WPA?
Necetitas la llave correcta par decodificar un señal WIFI.
Parece que todos alrededor de ti han puesto en uso su encrypcion en el "router". Gratis no hay. No tienes subscripcion con un ISP (Internet Service Provider)? Regresa donde tu prima y pregunta si ella anda cual conexion con cual codigo :)
