Opening the case of a Pelonis TWS5 fan may vary depending on the specific model and design. However, most fans have screws that hold the front and back grilles together. To open the case, you will need to locate and remove the screws that secure the grilles.
Here are some general steps you can follow to open the case of a Pelonis TWS5 fan:
- Unplug the fan and let it cool down if it has been running.
- Locate and remove any screws that are holding the front and back grilles together. These screws are usually located around the perimeter of the grilles.
- Carefully remove the front grille by pulling it straight off the fan. This may require some force, but be gentle to avoid breaking any clips or connectors.
- Remove the screws that secure the back grille to the motor housing. Depending on the design, you may need to remove a plastic cover or access panel to access these screws.
- Carefully remove the back grille by pulling it straight off the fan.
- With the grilles removed, you should have access to the fan blade, motor, and other internal components.
Note that opening the case of a fan may void the warranty or cause damage if not done correctly. If you are unsure or uncomfortable with performing this task, it may be best to consult a professional or contact the manufacturer for assistance.
