My Toro Zero Turn Lawermower (54" blade) will not go forward or backward. Blades will engage and mower engine works fine. The pins are pulled out and down for mowing. The belt is new and is routed correctly. Was mowing fine and then it stopped moving.
SOURCE: My riding mower workes fine fore about 45 mintes
Im assuming the tractor is a hydrostatic, in this case when the transmission starts to go...thats it, call the company and find a replacment or get another tractor. unfortunately rebuilding them isnt all that worth it
SOURCE: Craftsman riding mower blades will not engage
maybe the safty switch under seat might be starting to go out if that switch doesn't work the blades wont come on at all for safety
SOURCE: Craftsman zero turn - blades won't engage
The PTO switch contacts to operate the clutch that starts the blades is defective. I have replaced mine and the new one just failed again. Sears must know this is a defect problem but so far they are quiet about the problem
SOURCE: 24 hp LA165 mower. While mowing
check the connecting rod to the tranny. follow the gear handle and you should find a rod connecting the handle to the axle make sure you're in neutral and adjust the rod until the handle starts to move
