Firam 250mg Buy Firam 250mg Online, uses, price, dosage, cost
SOURCE: electric mobility Rascal 265 LE scooter won't run
Are you sure the batteries are charged ? Is the Battery charger charging ok ? Are the batteries connected ? take off seat and cover to check battery leads, does the key fit in the lock okay ?
SOURCE: Rascal mobility scooter will now only go backwards
On some scooters it is possible to change the polarity of the motor. If its a two brush motor (most are) you can just swap the red and black wires around in the connector plug for the motor. Make sure you get the right wires if you do this but I have to point out that there is obviously a problem with the scooter and I would strongly advise you to get it looked at by your local dealer as the problem is potentially serious and may cause other problems aswell. I cant really understand why it would only go backwards. May be a throttle pot problem or main controller fault. Either way, as I said, best get it looked at as even if you do swap the wires, it is most likely that the scooter will only travel forward at the usual speed for reverse, normally 2mph! Hope this helps...
SOURCE: Where can I get repair on a Rascal Little Rascal made by Electric Mobility
You can use my app to help you find out how to repair your Rascal Scooter Doctor App , If you are looking for a technician in your area then try Mobility Parts and Service Official Rascal Parts Supplier .
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
