I have a spare (new) spout body.
1 under the sink turn off both water supplies
2 disconnect the supply lines at the on/off valve EZer than at faucet
3 under sink unscrew the retaining nut(s)
4 on top wiggle or pry the faucet and lift up and remove.
5 know you can replace the spout and don't forget the new O ring that's why it leaks anyway. you really just need the new washer O ring .
6 Reinstall check for leaks
7 caulk around faucet.
Hope this helps Mike
SOURCE: price phister marielle kitchen faucet is leaking
Take the faucet back to where it was purchased as I believe PF has a lifetime warranty on their products.
SOURCE: I have a price Pfister Marielle kitchen faucet.
There is an o-ring around the valve body inside the outer shell. This needs replacing -- sometimes you can match these at hardware stores.
Shut water off, remove handle, pull up outer shell, you'll see the o-ring.
More info, let me know.
Charlie
Testimonial: "Thank you...problem solved :-) No more leaks. "
SOURCE: Have a American Std 4453 series kitchen faucet.
You have to lube the seals. New seals will be much firmer than leaking ones...but clean and lube is necessary.
