SOURCE: Problems with Kyocera Mita FS-1920
Make sure that your paper sizes match in the control panel of the printer in Windows. It will not only cause the duplex not to work but could cause jamming problems as well. When printing in duplex mode, make sure it is turned on.
SOURCE: Can't print on Kyocera km-2550
I have an HP 1350 all in one printer/scanner. It was printing fine until I wanted to scan a document. I pressed the scan button and now its stuck there. I can't get it out of scanning. I tried turning it off, unpluging and replugging. Can you help me.
SOURCE: I'm try to print a PDF file by Kyocera CS-2550
change the driver from kpdl to pcl xl, this is normal problem with pdf files. you do this from ur computer driver.
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
SOURCE: the kyocera km-2550 is giving
go to printer properties, printing preferences and set the paper size to A4 or the size you are sending
