Hi!
Could the manual help you? https://manualsbrain.com/en/manuals/328708/?page=8
SOURCE: Not in working Xerox Work Center EP220
look at the manual regarding faxes stored in memory the setting may have been changed and now is holding you fax ion memory.
SOURCE: Need to have the serial number installed in machine.
To access the serial number from the Control Panel:
If the System Admin Tools has not been passcode protected, 'Passcode Protect' will be displayed. Continue with step 4.
NOTE: If the Enter button is pressed, 'Passcode Protect (No)' will be displayed. Press the Menu / Exit button to return to the previous screen, and then continue with step 4.
SOURCE: my ir3300 xerox machine not print out.please solve thins problem.
How are you trying to print? You need N boot rom. Press Counter Check. Do you see IR3300(IR2200N) or IR3300(IR2200). If you see the N then you should be able to print with it. If not, you can't.
In Service Mode (to get into this press Additional Functions (button with * on it) > 2 then 8 > Additional Functions) go to Copier > Display > Version. What do you see for BOOT-ROM (does it have a N at the end?). For PS/PCL what do you see?
If your BOOT-ROM is N and you don't have a number for PS/PCL then call a technician to install networked system software.
If BOOT-ROM is not N, buy a Network Multi-PDL Kit C1 and get a technician to install it and load N system software.
If BOOT-ROM is N and you have number for PS/PCL check your IP settings. Make sure that DHCP is turned off. Set up your printer using an IP port with the static IP address assigned to the copier.
Use PCL5e or PS drivers, don't use PCL6.
SOURCE: not getting dry prints using canon 3300 xerox machine
1) is it canon ir 3300 machine?
2) if it is what does it mean NOT DRY completely?
#) My ques is that you need to eplace fixing film
SOURCE: authorization code for photoshop cs3 Please help
if you have purchase this s/w you can call customer support they will solve your problem. one suggestion for you don't show your product no. on web.
