Washing Machines Logo
S
Steve Posted on May 31, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Will a whirlpool AWE 6317 washing machine start wash cycle if drum lid is not properly locked?
Steve Pack
Level 3:
  • Whirlpool Master 7,121 Answers
  • Posted on May 31, 2018
Steve Pack
Whirlpool Master
Level 3:
Answers
7121
Questions
Helped
2271592
Points
27880
No it is a safety mandated item, replace lock
5 Related Answers
Anonymous
  • 641 Answers
  • Posted on Jul 26, 2007
SOURCE: washing machine does not stop filling
Does the machine start working normally after turning the wash cycle manually ?
dctpete
  • 3 Answers
  • Posted on Oct 14, 2007
SOURCE: fisher paykal top load washing machine
I had the same problem. I unplugged the machine for a while (overnight) and it then worked properly when I plugged it back in. Probably just a circuit board issue that was cleared with the power removed.
Anonymous
  • 1314 Answers
  • Posted on Mar 12, 2008
SOURCE: AWE 2516 The lock status is on. Not able to wash
what is the brand and model number of this unit if you hace an owners manuel look up control lock feature
Anonymous
  • 3361 Answers
  • Posted on Mar 23, 2009
SOURCE: Drum not spinning during some spin cycles
Replace the direct drive coupling.
Anonymous
  • Posted on Dec 11, 2009
SOURCE: Washing machine will not drain.
I have the same problem. If I press on the lid by the switch it starts up and finishes the load. Hope this works for you!
1helpful
I'm using a whirpool AWE 6317 toploader washing machine and I think I left the inside doors open.
This appears to be a 'compact' machine. I can't find anything in the manual about doors inside. I presume it is some type of soap dispenser?
https://www.google.com/search?q=whirlpool+awe+6317+not+working
A call out is likely to be around $80 to $100. If you are on Facebook, find a local area group and ask for recommendations for a one man, independent repairer. You can ask the cost in advance. The usually charge a call out amount which includes 30 minutes and then so much for every 15 minutes after the first half hour.
https://www.manuals.ca/whirlpool/awe-6317/manual?p=4
F06 error on a AWE 9663 whirlpool washer
To remove the code, press pause or cancel button twice and the power button once. If the code is still displayed, unplug the washer or disconnect the power for one minute. Items were detected in the washer during the Clean Washer cycle. Remove items from the drum and restart the Clean Washer cycle.Jun 13, 2019
Error Codes in Front Load Washers - Whirlpool Home Appliances
https://producthelp.whirlpool.com > Washers > Washer_Product_AssistanceSearch for: How do I clear the error code on my Whirlpool washer?
2answers
Whirlpool top load washer washes, rinses, drains lid lock unlocks no spin
Bypass the lid lock so it is seen as activated all the time.
Won,t work just flashing blue light
Cycle light flashes, but machine wont start - Kenmore Elite ...
https://www.ifixit.com/.../Cycle+light+flashes,+but+machine+wont+...
iFixitThe Kenmore Elite HE3 is a washing machine by Kenmore. ... Whatever cycle I choose, the light just flashes and holding the start button ... I don't seem to have a black pin....the normal wash button just keeps flashing and won't let me start or .
The good ol' Whirlpool Lid Lock Flashing Light Problem - ApplianceBlog
www.applianceblog.com/.../42456-The-good-ol-Whirlpool-Lid-Lock-Fl...
Dec 11, 2013 - 10 posts - ‎3 authors Red Lid Lock light flashing intermittently when you try to start a cycle. ... Mode -- Lid Lock won't work, nor will anything that requires the lid to ... Once the lid has locked the second time, the washer ... shuts down with the lid lock blinking; go back into diagnostic codes and look for shifter or speed sensor errors ...
Lid locked light on, will not release
The lid lock light won't stop blinking. - Fixya
www.fixya.com/.../t14714916-lid_lock_light_won_39_t_stop_blinking
Oct 21, 2012 - The lid locked keeps blinking and I can not start a cycle. - WhirlpoolLSB6200KQ Top Load Washer question. ... Whirpool cabrio wtw5500xw top loadwasher will not start lid light flashes then goes out and into flashing pause ...
Whirlpool washing machine_ lock light flashing_ nothing ...
? 1:53
www.youtube.com/watch?v=zrV9w6Z5LAU
Mar 3, 2012 - Uploaded by briantaylor62 Whirlpool washer wont start a cycle, lid does lock and the locklight ... a cabrio as well that just has the lid lock flashing and nothing happens , I ...
Flashing Lid Lock Light: How to Troubleshoot Errors on Your ...
? 1:23
www.youtube.com/watch?v=nttHsAX2_OM
Mar 27, 2015 - Uploaded by searspartsdirect
The lid lock light on VMW washers, made by Whirlpool, Kenmore and Maytag, will flash whenever there is a ...
Kenmore 2800*010 will not fill
It sounds like you have a bad lid switch. There is a tech sheet taped to the inside of the front of the cabinet. The part # is w10404050, made by whirlpool.
My washing machine fills up with water but does not continue the wash cycle. Sometimes when you slam the lid the washer will continue the wash cycle to the end. Other times the washer stays filled up...
Sounds like the lid safety switch is either out of adjustment, or needs replacement.
Most washers will fill with the lid open, but no continue a cycle where the drum or agitator spin, unless it senses the lid is closed.
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
