1. Open the oven door and remove the 2 screws at the side of the inner glass window 11cm above the hinges and lift off the door. Place it somewhere safe!
2. Remove the 4 screws that you can see nearest to the left and right edges of the oven with the door removed. These secure the oven to the kitchen unit.
3. Slide the oven forwards about 20cm out of the unit, being careful not to pull on the cable.
4. Each hinge is held in place by 2 screws at the side of the unit now exposed, about 18cm apart. Remove them and slide out the hinges. Reassembly is the reverse of the above.
5. Note that the hinges have no means of adjustment. If not working properly, renew them.
SOURCE: the hinge on the main oven door of my heritage
Well, you can try STOVES and see what they will charge, and/or try espares. Once you have the part number, google that to see if anyone else can supply.
You may want to think about replacing both hinges and the springs at the same time, to ensure the door works/closes properly. Also, check the rubber seal round the door, then tend to become brittle when at the end of their service life, so it may pay to include that with the order as well.
SOURCE: how to remove door on stoves EL716 toop oven
Click on the link below to watch a video that explains how to remove the door on most modern ovens.
http://www.appliancerepairlesson.com/2011/01/22/oven-door_diy-oven-repair-help-101/
SOURCE: dhow do i remove stoves efa600H oven door hinges?
SOURCE: how to remove broken-off metal part of oven bulb in Stoves 900EF oven.
SPRAY IN PRODUCT LIKE NUT BUSTER, OR PENETRATING SOLVENT WD40. WITH SMALL SCREWDRIVER GIVE A QUICK TAP WITH HAMMER. IT SHOULD LOOSEN UP JUST ENOUGH GRAB WITH A NEEDLE NOSE PLYERS AND TURN LEFTY LOOSY /RIGHTY TIGHTY. GO IN CORRECT DIRECTION!!
SOURCE: Does anyone know where I can get a replacement timmer for Stoves oven 900ef - 059040411
You can find the online at several sites, they will be universal however so you will have to know the diam. and how it connects etc, but I am sure you can find something that will work.
